Another wiring problem
924ttrouble
PostPosted: Wed Jul 09, 2003 2:12 pm    Post subject: Another wiring problem Reply with quote
931 everything is once again grounding out and I can't fine out why!!!!
My coil is ground again and I can't get my fuel pump relay to energize.
I had this problem before and rebuild my wiring harness in the engine compartment and some wiring under the dash. Now I have more burnt wires under the dash and can't figure out where this stuff is grounded. This is a nightmare, I can't get my hands under the dash to trace the wire back. any test that can be preform to trace back wiring and how do you get under the dash and not mess everything else up in the process. Also when I replaced the head and tried to start the car my fuel pump shorted out and so did my ignition switch. both were replaced already, and still grounded some where. any help out there. Does anyone have an wiring harness they want to sell
PostPosted: Wed Jul 09, 2003 2:19 pm    Post subject: Reply with quote
what year is the 931?
3 928s,
924ttrouble
PostPosted: Thu Jul 10, 2003 2:41 pm    Post subject: Reply with quote
the car is a 1982 924 turbo. Will a wiring harness from a 1987 944 fit in a 1982 924
