Assistance Requested - Part Numbers
shenry1307
PostPosted: Fri Jun 27, 2003 3:13 pm    Post subject: Assistance Requested - Part Numbers Reply with quote
Hey, folks.
I finally snatched enough time to put the old girl up on stilts, and while I was beneath, I pulled these numbers off of these parts:
Turbo -- There was an original plate pop-riveted to the turbo. The numbers, listed on four separate lines, are:
    B95DX62
    K262664G4 10
    85 723 0120
    5326 970 6407
And, die-cast on the side were the numbers 5326 1023303
Tranny -- 016/Z Snail shell
    31 01 000099
I can (and am) research these number myself, but I thought some of you die-hard information junkies (like me) would like to help solve the puzzle.
Later, I'll share the "puzzle" info with you.
Any additional help decoding these numbers would be greatly appreciated.
SH3
'79 EUR 931 (Modified)
"Excuse me, but have you seen my mind?"
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger
PostPosted: Sat Jun 28, 2003 2:47 am    Post subject: Re: Assistance Requested - Part Numbers Reply with quote
    B95DX62
    K262664G4 10 Type of turbo you have a K26 2664 the G4 and 10 I believe corrospond to compressor and housing
    85 723 0120, 5326 970 6407 one of these #'s I think is the serial #
Tranny -- 016/Z Snail shell, if it is a turbo car it will NOT be the 016/Z it would be a G31
    31 01 000099
3 928s,
CMXXXI
PostPosted: Sat Jun 28, 2003 4:08 am    Post subject: Reply with quote
Turbocharger: Line starting with K26 is a factory "code" of how the unit was put together. It denotes the setup of turbine/compressor/housing configurations. The K26 is "modular" in that the same "K26" designation can be assembled into different configurations with varying performance characteristics. Some Audis also used the K26 turbo.
The line beginning with 5326 is the KKK in-house part number for the assembled unit.
An educated guess says that the numbers cast into the parts are manufacturer part numbers.
The numbers on my data plate are:
Grosse K26-2470R6.10
ATL NR 82 057 0125
AUSF NR 5326 970 7007
These numbers came off of what was in my car, and was a dealership replaced unit, probably a factory rebuild. I don't think that any of the numbers are actual serial numbers because 924 Turbo has the identical numbers on his unit. Neither of us have a number like the first one you quote.
See some additional info in these two posts
http://www.924board.org/viewtopic.php?t=7768
http://www.924board.org/viewtopic.php?t=6715
The transmission number is the transmission serial number.
G31 01 is the series (NOT a 016/Z), and the numbers that follow are just the serial number. Mine is G31 01 / 000642 or something like that. US model cars have the G31.02 series, but I don't know exactly what makes them an "02" model. My guess is gear ratios because of the difference between US and European markets (speed limits, emissions, etc)
We're just a fountain of off-the-wall info, aren't we?
'79 Eurospec 931
john h
PostPosted: Sat Jun 28, 2003 1:23 pm    Post subject: Re: Assistance Requested - Part Numbers Reply with quote
    B95DX62
Lizard's correct in that the type and compressor combination. The 5326 series of number sin the KKK internal numbering sequence to tell them how the unit is set up. The K26 series of numbers is the customer numbers same as we call a Mercedes a 1975 280 - te factory calls it a W126.
If the plate on the turbo is blue then the unit is a genunine unit hasn't been rebuilt by KKK factory or one of their authorised distributors. when the KKK guys rebuilt them they are supposed to put a red plate on signify ing that it's a rebuilt unit.
CMXXXI
PostPosted: Sat Jun 28, 2003 2:35 pm    Post subject: Reply with quote
I had posted this info to the Board several times since joining here, having never seen it before in the archives. Do you know how to interpret the internal numbering "scheme", as far as compressor, turbine and scroll housing set up is concerned?
My data plate was blue, but I suspect it was a rebuild since it was a dealership replacement (79 model, 83 replacement) and the number on the invoice was "odd" - 931.123.002.FX. As outlined in other posts, the newer K26's have the recesses for the ring type seals instead of using flat gaskets. This replacement unit is outfitted to use the ring seals.
'79 Eurospec 931
Zuffen
PostPosted: Sun Jun 29, 2003 1:19 pm    Post subject: Reply with quote
I bet corky bell has the key to the numbers
years ago I did have the outline of what was what, my notes are around
the 6407 is the one key
there were like 16 different units built and designated in that last four numbers on that string
I think the first set is the turbine, the middle is the housing and the last is the compressor, just my quess....as the unit really only vary in spool up times to full operating peak.
I don't see how changing the turbine would be that helpful, plus the cost of manufacturing a variety of those would be costly.
Jus thinking outloud
Bob Dodd - 924turbo@cox.net
931 1982, 944 1982 euro, 924S 1988SE, 93 968 tip 06 Silver Cayenne S, 06 Black Cayenne S
I have Way too many cars, parts for the 931,944 and 951
