924martinirossi Guest
Posted: Thu Oct 25, 2001 6:25 am Post subject: |
My 81, 931 cuts off after about 15 sconds of running. I can rev it up to 5,000+ and it does not miss a beat, however, when the idle drops down to around 1,ooo it runs for a few more seconds then dies. The car just refuses to start after that.
In trying to locate this problem and this is what I repaired already:
Replaced fuse/relay pannel
Replaced fuel pump relay (with correct one)
Cleaned all grounds above relays
Repalced fuel pump (had a bad one)
Removed and cleaned fuel distruibtor
Flushed lines to and from the tank
New plugs installed
Gas flows freely from both input and output of fuel filter and fuel dist. lines.
13.85 VDC at pump.
Any other suggestions?
Michael
Posted: Thu Oct 25, 2001 6:52 am Post subject: |
Forgot to add that my boost switch (on intake) has been grounded to block. The PO said it is not working. This car is an 81 931.
Michael |
Posted: Thu Oct 25, 2001 9:05 am Post subject: |
Got it figured out. Turns out that my spare fuel pump was no spare at all. It was cutting out. When I got the car started it ran and when the relay was "jumpered" I heard the in-tank pump going. After I figured that out I took a hammer to it and it works now. Also on the fuel distrubitor there was a toothpaste cap siliconed over this small hole. Without this cap the car would not rev up and backfire thru the air meter. A 11 cent cork solved the problem.
I drove it over to the guy I bought it from and he cried. What I didn't know when I bought it was that he had spent about $4k on it and then let it sit since 1997.
It even burns rubber.
Happy 931 driver
Michael
My 80 931 still sits in a garage. It has been there for over 19 months. |
