jjadczak
Joined: 03 Jan 2003 Posts: 346 Location: Accokeek, MD
Posted: Wed Jun 04, 2003 12:41 am Post subject: Pocono Setup |
Ok ramblers let's get rambling. We are going to Pocono later this month and running a double regional SCCA race. Dad on Saturday and I on Sunday. The configuration is a bit different than what SCCA has run in the past. At Pocono, they incorporate the infield with NASCAR turn 1 and 2 (tunnel turn that unfortunately ended Bobby Allison's NASCAR career). The course will be run clockwise with a "bus stop" chicane along the Long Pond straight connecting NASCAR turns 1&2. We will be running on the banking over the tunnel turn onto the Long Pond straight, get up to 5th then brake hard for the chicane. We enter NASCAR turn one (aka "The Bowl") from the opposite direction and then onto the front straight . If your a NASCAR fan you'll get a chance to see what I'm talking about this weekend when the "Hollywood Hotel" makes it's annual stop there for the PA 500.
The question is, in order to keep the ass end planted in the Bowl we thought to add an extra pound or two the the left side tires and maybe raise the left front spring perch a rotation or two or three.
Has anyone else run at Pocono or a similar high banked oval who could tell us what we need to do? When I ran there last year for a driver's school I was on street tires, ran without a spoiler, had stock 924 springs, and stock torsion bars. Let me tell you it was very scary as I ran the same direction as NASCAR does and all the car wanted to do was have the back end come around. She was running real loose and had plenty of oversteer. Now we have 350# front springs, 30MM rear torsion bars, larger front 944T sway bar. I think the formula I laid out should work. Am I in over my head? No way I am going to get blown away in the Bowl by an ITC Rabbit again. This time his ass is mine!!!
Your thoughts are greatly appreciated.
Jeremy
#53 924 ITA SCCA |
wdb
Posted: Wed Jun 04, 2003 11:53 am Post subject: |
| does SCCA allow putting the battery in the spare tire well .40 lbs over the rear wheels might help plant the rear end . |
wdb
jjadczak
Posted: Wed Jun 04, 2003 11:40 pm Post subject: |
| Not sure SCCA rules would allow me to put the battery in the rear like that because the current location protects the driver from fires/acid spills being on the other side of the fire wall. Besides, I'm not sure we could secure it properly and I don't want to buy a battery box. I do like the idea of more weight in the rear. We can put back in the spare tire/dougnut which IS legal. Thanks for helping get my wheels in motion!! |
wdb
Posted: Wed Jun 04, 2003 11:56 pm Post subject: |
you didnt read the link .
Relocation of the battery or batteries is permitted but not into the passenger compartment.
The area behind the rearmost seat is not considered to be within the passenger compartment. |
jjadczak
Posted: Thu Jun 05, 2003 12:49 am Post subject: |
Thanks, but I'm not running Solo I or II. I run SCCA Club racing Improved Touring. I still think that moving the battery to that cavity is not a safe option as it would be difficult to clamp down.
Thanks again. |
Joined: 29 Jul 2001 Posts: 9073 Location: Royal Oak, MI, USA
Posted: Thu Jun 05, 2003 5:28 am Post subject: |
Moving the battery is not legal in IT. _________________ Vaughan Scott
