Joes924 Guest
Posted: Thu Oct 11, 2001 3:06 am Post subject: |
After recieving a custom cam and maybe just lapping the valves and replacing valve seals
Am I gonna need differant notched adjusting screws. I was going to stiffen the springs but decided not to.
Joe D.from Denver Colorado residing in Oregon
RTFAQ
[ This Message was edited by: Joes924 on 2002-05-26 18:05 ] |
eturbo924 Guest
Posted: Fri Oct 12, 2001 10:06 pm Post subject: |
Joe
You need to ask the shop about the material removed off the base circle of the cam. You can then determine what size screws or shims that you will need.
More spring force is always better if you plan more high rpm trips. I had my stock springs measured and shimmed to get more force. You need to make sure they do not get over stressed though.... also that they do not go solid. So make sure you use a good shop or take some real accurate measurements.
Eric |
Joes924 Guest
Posted: Sat Oct 13, 2001 4:06 pm Post subject: |
Well theres not to many shops around here that do 924s
.Im gonna get a cam from Schnieder 274f
Its my 924 ..and I like it ...and yes its getting faster/ 1979 924 Joe
[ This Message was edited by: Joes924 on 2002-05-26 18:07 ] |
