skystryd
Posted: Mon May 05, 2003 4:03 pm Post subject: syncro's? |
Greetings all.
Been 'lurking' Its de lurk time. 82 na. shifting is a problem. reverse grinds unles I go thru 2 or 4th..
So .. does this sould like syncro's? Does not shift easilly..
Have 'down graded to 924 in the hopes it will be easy to work on or at least easy to deterime whats going on.
past 944/912's always seemed to be that one action that was just beynd my skills.
thx.........
chuck
n tx..
any listers out there from dfw metro area? would like to do the face to face thing. _________________ Throw dirt and 'you' lose ground. |
ZV
Posted: Tue May 06, 2003 2:10 am Post subject: Re: syncro's? |
| skystryd wrote: | Greetings all.
thx.........
chuck
n tx..
any listers out there from dfw metro area? would like to do the face to face thing. |
Reverse has no syncho. It sounds like clutch drag. The clutch probably isn't completely disengaging so the transmission is still spinning when you're putting it in reverse. If it's a cable clutch, adjust the cable at the release lever arm. If it's hydraulic, there's no real adjustment (at least, nothing near the extent that a cable allows) which means you'll probably have to open everything up and put a new clutch in.
Since 2nd and 4th have synchos, the clutch drag is overcome by the synchros and you aren't grinding gears, but since reverse isn't synchronised (it almost never is, even in modern cars) there's nothing to overcome the clutch drag.
I would recommend that you fix the clutch drag soon, since it will stress the synchroes and a clutch is much easier to replace/adjust than the synchros are.
Aaron _________________ Shifting is an art, learn it, love it, live it.
1976 Porsche 914 2.0 - Driving Restoration.
1987 Porsche 924S - Daily Driver |
Roger
Joined: 06 Jan 2003 Posts: 1235 Location: Cordova, TN
Posted: Wed May 07, 2003 6:35 am Post subject: Re: syncro's? |
| skystryd wrote: |
Have 'down graded to 924. |
Slumming???????????????????
Thanks for stopping by...dont worry about closing the door on your way out
just kidding....Welcome _________________ 1981 924 NA
still can't help but smile when you see one tumble down the stairs. |
skystryd
Posted: Wed May 07, 2003 1:24 pm Post subject: Was stupid |
That did sound/look that way. Stupid of me. While not the first or probably last stupid thing.. I try to reduce them.
Was not my intention, do not think that way..but it did sound/look it. A case of foot in mouth or keyboard in @#$$?
Can't think of a bad Porsche.. past ones for me were poor choice of auto to begin with..by that I mean they needed help or attention beyond my skills and pocket book. One of the nice things about the 924 is that is "seems" closer to what I can handle both skill and $ wise.
I will now do 30 minutes of standing in the corner ??
And then try to work out the problem with the clutch..
chuck
n tx _________________ Throw dirt and 'you' lose ground. |
Roger
Posted: Wed May 07, 2003 2:07 pm Post subject: |
Mine has somtimes had troublegetting into reverse. Its seems to happen once or twice a week. This car has had this problem for 20 years its been in the family. I dont worry about it. If you rev the engine a little then it will slide into reverse. _________________ 1981 924 NA
Porscheaddiction
Joined: 03 Nov 2002 Posts: 431 Location: Cornwall, Ont, Canada
Posted: Wed May 07, 2003 2:16 pm Post subject: |
Are you reving the engine as you are putting it into reverse??
Chris |
Roger
Posted: Wed May 07, 2003 2:50 pm Post subject: |
No if it doesn't want to go into reverse I put it in nuetral and raise the RPM's to about 1400 let it settle back down to idle and it slides into reverse. _________________ 1981 924 NA
ZV
Posted: Wed May 07, 2003 3:20 pm Post subject: |
| Roger wrote: | | Mine has somtimes had troublegetting into reverse. Its seems to happen once or twice a week. This car has had this problem for 20 years its been in the family. I dont worry about it. If you rev the engine a little then it will slide into reverse. |
He said the other gears were hard to engage too, which typically indicates clutch drag also since the synchros are having to work very hard to overcome the dragging clutch.
Joined: 29 Jul 2001 Posts: 9129 Location: Royal Oak, MI, USA
Posted: Wed May 07, 2003 10:31 pm Post subject: |
Yeah, bleed that clutch...
Welcome! _________________ Vaughan Scott
