Oil Leaking on to the exahust, Distrubutor or ????
Phogphire1
PostPosted: Mon May 05, 2003 5:20 pm    Post subject: Oil Leaking on to the exahust, Distrubutor or ???? Reply with quote
I have oil leaking from the back of the Block dripping down on to the exhaust. I have a new valve cover gasket ( Valve cover just beadblasted to clean up the corriosion and make it look new) Do the distrubtors have oil seals or gastkets? Are they a common leak Point? or is the Head gasket leaking at the back left of the block ? I can't see behind the block to try to pin point the leak. any ideas? I figure that it could be the dist. because of the slant engine ( see simple but crude diagram below)
. Dist
\ engine
" pipes
Extremism in the defense of liberty is no vice. And moderation in the pursuit of justice is no virtue.
Life, Liberty and the Pursuit of thoose that dare screw with it.
crazyinkc
PostPosted: Mon May 05, 2003 10:26 pm    Post subject: Reply with quote
The housing that mounts the distirbutor to the head was leaking real bad on my 78. I think it was held on by 3 bolts. You might want to look at that housing first. Just a tought. It has been a few years since I fixed it.
wdb
PostPosted: Mon May 05, 2003 11:26 pm    Post subject: Reply with quote
you can put some high temp silicone around the distributor housing ,or the valve cover seam, to stop the oil leak temporarily , till you get the time to take it all apart, and fix it right. be sure to clean it well with solvent .
Roger
PostPosted: Wed May 07, 2003 12:54 pm    Post subject: Reply with quote
Only way to tell is to clean up the oil and take a closer look at where its leaking from. Distributor is a good bet though.
1981 924 NA
Phogphire1
PostPosted: Thu May 08, 2003 6:14 am    Post subject: Reply with quote
.45c Paper Gasket, no more burnning oil smell everytime I stop and get out of the car = PRICELESS. I had Cleaned up the back with some break cleaner and bought a little inspection mirror and I could see a little piece paper gasket hanging down. on the back side of the distubtor. I was'nt sure if anybody had run in to a rear block leak it was in the wrong place to be the rear main. I am glad that it was'nt the other distributor gastet though.
