syncro's?
skystryd
PostPosted: Mon May 05, 2003 4:03 pm    Post subject: syncro's? Reply with quote
Greetings all.
Been 'lurking' Its de lurk time. 82 na. shifting is a problem. reverse grinds unles I go thru 2 or 4th..
So .. does this sould like syncro's? Does not shift easilly..
Have 'down graded to 924 in the hopes it will be easy to work on or at least easy to deterime whats going on.
past 944/912's always seemed to be that one action that was just beynd my skills.
thx.........
chuck
n tx..
any listers out there from dfw metro area? would like to do the face to face thing.
Throw dirt and 'you' lose ground.
ZV
PostPosted: Tue May 06, 2003 2:10 am    Post subject: Re: syncro's? Reply with quote
skystryd wrote:
Greetings all.
thx.........
chuck
n tx..
Reverse has no syncho. It sounds like clutch drag. The clutch probably isn't completely disengaging so the transmission is still spinning when you're putting it in reverse. If it's a cable clutch, adjust the cable at the release lever arm. If it's hydraulic, there's no real adjustment (at least, nothing near the extent that a cable allows) which means you'll probably have to open everything up and put a new clutch in.
Since 2nd and 4th have synchos, the clutch drag is overcome by the synchros and you aren't grinding gears, but since reverse isn't synchronised (it almost never is, even in modern cars) there's nothing to overcome the clutch drag.
I would recommend that you fix the clutch drag soon, since it will stress the synchroes and a clutch is much easier to replace/adjust than the synchros are.
Aaron
Shifting is an art, learn it, love it, live it.
1976 Porsche 914 2.0 - Driving Restoration.
1987 Porsche 924S - Daily Driver
Roger
PostPosted: Wed May 07, 2003 6:35 am    Post subject: Re: syncro's? Reply with quote
skystryd wrote:
Have 'down graded to 924.
Slumming???????????????????
Thanks for stopping by...dont worry about closing the door on your way out
just kidding....Welcome
1981 924 NA
skystryd
PostPosted: Wed May 07, 2003 1:24 pm    Post subject: Was stupid Reply with quote
That did sound/look that way. Stupid of me. While not the first or probably last stupid thing.. I try to reduce them.
Was not my intention, do not think that way..but it did sound/look it. A case of foot in mouth or keyboard in @#$$?
Can't think of a bad Porsche.. past ones for me were poor choice of auto to begin with..by that I mean they needed help or attention beyond my skills and pocket book. One of the nice things about the 924 is that is "seems" closer to what I can handle both skill and $ wise.
I will now do 30 minutes of standing in the corner ??
And then try to work out the problem with the clutch..
chuck
n tx
Roger
PostPosted: Wed May 07, 2003 2:07 pm    Post subject: Reply with quote
Mine has somtimes had troublegetting into reverse. Its seems to happen once or twice a week. This car has had this problem for 20 years its been in the family. I dont worry about it. If you rev the engine a little then it will slide into reverse.
1981 924 NA
Porscheaddiction
PostPosted: Wed May 07, 2003 2:16 pm    Post subject: Reply with quote
Are you reving the engine as you are putting it into reverse??
Chris
Roger
PostPosted: Wed May 07, 2003 2:50 pm    Post subject: Reply with quote
No if it doesn't want to go into reverse I put it in nuetral and raise the RPM's to about 1400 let it settle back down to idle and it slides into reverse.
1981 924 NA
ZV
PostPosted: Wed May 07, 2003 3:20 pm    Post subject: Reply with quote
He said the other gears were hard to engage too, which typically indicates clutch drag also since the synchros are having to work very hard to overcome the dragging clutch.
Aaron
PostPosted: Wed May 07, 2003 10:31 pm    Post subject: Reply with quote
Yeah, bleed that clutch...
Welcome!
