Posted: Fri Apr 11, 2003 3:46 am Post subject: Inside electrical problem need ,help asap |
All the electricals to the guages quite fuel level,tach oil,temp,even the alt guage quite worken..car starts fine alts putting out I think Ill go have it checked..guages dont work they just stopped though the little guage lights turn on and the signal indicators light. Its like the movie gremlins when the gremlin chews through the cord to the clock so itll get fed after midnight and he notices the clock hands arnt worken and goes 'whats goin on here' while holding the clock and tracing the wire to its chewed off end.
Give me some ideas....
Ill have pics later today..of shift rod hole and 44 suspension. _________________ 1979 porsche 924 Na
Posted: Fri Apr 11, 2003 3:50 am Post subject: |
2 words "fuse box" _________________ 3 928s, |
Posted: Fri Apr 11, 2003 5:22 am Post subject: |
nope
the alt only putting 12.7 volts and around 16amps...
should be more like 14 or 15 volts and around 75 to 90 amps
The onlt thing I did to the electricasl system lately is
hook up my tach the green wire that used to go to the stock coil
to the back of my msd to get the tach worken that was
yesterday it worked for awhile. Now
all of a sudden the tach started jumping around itsd not accurate now and the electics to all the guages needles quite.. fuel,tach,oil.volts
those dont work atall..I just checked the alt.I looked at all the wires by pullen the guage cluster out there fine ..I also pulled the smaller 3 guage cluster out to check it ..its fine
What happend. _________________ 1979 porsche 924 Na
Posted: Fri Apr 11, 2003 6:22 am Post subject: |
well first you said the alt is putting out if it is at 12.7 it is not putting out, it should be at 13.8-14 volts, have you ried disconnecting the tach wire and does it fix the problem _________________ 3 928s, |
Posted: Fri Apr 11, 2003 6:50 am Post subject: |
yea I disconnected it also I just switched out the alt.. so Ill go and have the new one I took that registered 12.7 and the one I just put in though the batterys not draining at al the voltage guage wont work this is to weird..I need help.. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Fri Apr 11, 2003 7:08 am Post subject: |
if this was at idle then it could be that the alt just wasn't turning fast enough _________________ 3 928s, |
Posted: Fri Apr 11, 2003 8:26 am Post subject: |
I checked the alt I just put in and at idle it was putting 13.46
volts back... The alt I took out the new one I just took it to a auto parts store where they know beans I think a girl tested the alt..though she said seemed the diodes were toast
Now I forgot to mention that when I first started the task of hooken up the tach yesterday I removed the guage cluster to check wires to the tach I couldnt remember if I hadem hooked up or not... AsI had my hand up there to screw in the speedo cable I moved wires out of the way...
I didnt move em back and when I connected the battery and hit the power swich it smoked the insulation on a wire, smoke was coming out the dash I shut the power off and it stopped though I took off the battery cable also. I pulled the cluster out and the wire that got smoked was one of the black ones that go to the tach and another wire got it too it was black also and goes to the round connector that connects to the guage that holds the battery light gas guage and turn signal indicator the guage on the far left.. I looked at the wires and wrapped em with electrical tape as the plastic was melted off just in spots..It worked the tach was worken fine...then all hell broke loose.. and the guages quite worken. I have no powered guages everything else works.
Im goin ou there and take out the dash and trace those melted wires down and fixem also Ill take a look at the wiring schematic in haynes..
and use my engine anylizer that measures volts and amps. _________________ 1979 porsche 924 Na
Posted: Fri Apr 11, 2003 8:37 am Post subject: |
hmmm you know now I really wonder why they don't work
when you melt a wire ALWAYS replace the wire or it will give grief in the future _________________ 3 928s, |
Posted: Fri Apr 11, 2003 8:50 am Post subject: |
Ok got the cluster out and the dash just about ..any way on the big round hookup that hooks into the guage on the far left theres 2 wires melted there black and by looken at my haynes on page261 I see that connector lug 12 comes from the tach thats one and lug 7 thats the other goes to the ignition switch so ..the other tach wire goes to a continuation
current track its a double connection to the tach..If any one cares to share there views by means do so as long as its conductive to the
congruent task.  _________________ 1979 porsche 924 Na
Posted: Fri Apr 11, 2003 9:12 am Post subject: |
Ok dash is out now I chased the wire from the guage on the far left to the ignition and its toast. Im gonna replace it. theres 4 black wires that got it.. its the wires I pushed out of the way and didnt push back,
I get like that..sometimes
bunmmer _________________ 1979 porsche 924 Na
Posted: Fri Apr 11, 2003 10:18 am Post subject: |
Replaced the wires & checked it out all apart with the connections connected the guages still dont work with the replaced wires it seems ..Im stoppen its hocky night..Ill pull out a fuch and rest my legs on it.
I still must have a short or something missconnected.. _________________ 1979 porsche 924 Na
Posted: Fri Apr 11, 2003 10:59 am Post subject: |
Sure am glad Im off friday anyway I got the oil to work and the gas guage though no volt gauge its got me real edgy right now..
bummer, _________________ 1979 porsche 924 Na
Last edited by Joes924Racer on Sat Apr 12, 2003 4:14 pm; edited 2 times in total |
jamez
Joined: 03 Nov 2002 Posts: 401 Location: Chehalis, Wa
Posted: Fri Apr 11, 2003 11:11 am Post subject: |
| sounds like you probably just have another fried wire somewhere, or a wire not hooked up that you overlooked, or possibly a blown fuse... everything was working fine until you hooked up the tach and shorted the wires, right?.. I'm sure you'll figure it out... |
Posted: Sat Apr 12, 2003 4:24 pm Post subject: |
Everything works in the guage on the far left,the tach doesnt, or the
volt guage, the oil guage either. Ill test for current with
my engine anylizer it does both amps and volts..all though Im just looken for volts and how many.  _________________ 1979 porsche 924 Na
Posted: Sun Apr 13, 2003 4:46 am Post subject: |
Didi a a test on voltmeter with 8 flashlight batterys works fine
checked the volts on the existing hookup fo voltguage in car only have 4.5
so there still a short some where.
Most sports cars use a switched source for voltguage I dont know what the 924 uses might be the tach any way they use the tach or the heater
I checked the heater source and its putting out 12 with just the power on with the car started it jumps to 14.sothis is gonna be the source for this surrent path..I think it should power volts,oil,tach...though I should try to source the short on the existing it might be in the engine compartment wireing as I ve been thru the interior pretty well Im thinking I should maybe take it out or go for the engine bay wiring.. _________________ 1979 porsche 924 Na
