jamez
Joined: 03 Nov 2002 Posts: 401 Location: Chehalis, Wa
Posted: Sun Feb 23, 2003 10:10 am Post subject: 1996 LT1 into a 924 |
I have begun my project of installing an LT1 in my car. so far I have only removed the porsche motor out of my car, and have taken measurements and can say that it is going to be a very tight fit... I will be taking pictures of the whole process and will have a web page up soon, I hope to have it put together in less than two months (hope is the key word here I'll keep everyone updated as soon as I get the webpage up.... |
Alex Roy
Joined: 03 Nov 2002 Posts: 694 Location: Springfield Oregon USA
Posted: Sun Feb 23, 2003 12:21 pm Post subject: |
| Are you going to make your own conversion parts, or are you getting something along the lines of a renegade hybrids conversion kit and putting a 944 torque tube and transmission in? |
jamez
Posted: Mon Feb 24, 2003 2:20 pm Post subject: |
| I will be making all the conversion components myself... |
Posted: Tue Feb 25, 2003 9:29 am Post subject: |
can you take photos and measurements and stuff like that so people who want to do this in the future have an idea _________________ 3 928s, |
jamez
Posted: Tue Feb 25, 2003 4:20 pm Post subject: |
| yep, I am planning on documenting the whole process. right now I am just waiting on the clutch and flywheel (from a Z-28. ), then I will get started on it... |
PORSCHEV
Posted: Sat Mar 01, 2003 9:39 pm Post subject: |
I made all my own components for my conversion as well.....although I won't be able to give you any pointers for the next month ( going out to sea on a deployment). I have talked about the conversion lots on the board..and a search with my user name should find you alot of info of what I ran into.
Just be prepared for MANY unseen hurdels.... besides ...you wouldn't have taken the job on if you weren't prepared for the challange. _________________ 1976 924
1978-#53 "D" track racer. |
jamez
Posted: Sun Mar 02, 2003 5:03 am Post subject: |
| yeah I have seen the pictures of your car Porschev, looks great.. best of luck on your deployment... |
turbobob9242
Joined: 08 Feb 2003 Posts: 138 Location: Hinckely Ohio
Posted: Sun Mar 02, 2003 11:08 am Post subject: RE V8 swap in 924 |
Drop me an email! We can share swap problem stories.
I have a chevy V-6 in my 924 turbo now.
I'm upgrading with a Buick turbocharged GN motor!
www.turbo924.com
bward@newtekdata.com _________________ Bob Ward
80 9214 turbo, w 5.3 LS V8 |
jamez
Posted: Wed Mar 12, 2003 2:24 pm Post subject: |
well, I got a 951 tranny on saturday.. I just got the bellhousing from a 96 camaro which I was planning on using since I want to use a z-28 clutch and whatnot.. The camaro bellhousing sticks out a little too far on the clutch lever/slave cylinder part.. so I can either cut into the hump in my car, or consider using a different bellhousing... the camaro bellhousing will make the job very simple, all I will have to do is make a plate to bolt the torque tube to the bellhousing... someone said something earlier about hydraulic throwout bearings?? how does this work and would it allow me to get rid of the part of bellhousing thats in the way??
besides that everything is going fine.... the two major parts of the job are mating the engine to the torque tube, and making motor mounts... I'm not even worried about the engine mounts, but right now I have to make some decisions about the bellhousing... I have also taken out the pop up headlights and have made headlight covers with acrylic, and have started to make the headlight buckets, here are the lights I am going to use
http://www.hellausa.com/maineng/lev1b/lev2bb/lev3bbc/90mm%20module.html
I promise I will have pictures of everything up soon but right now since I haven't done any fabricating yet its not that important.... if anyone has some good imput on the bellhousing, besides buying one from renegade which is $1200 more than i want to spend, let me know.... thanks
RIP Barry Sheene, one of the greatest motorcycle riders ever.... |
jamez
plunger
Posted: Wed Mar 12, 2003 3:59 pm Post subject: |
I would check to see if the t.o. bearing is recommended for street use. When I talked to a tech guy at Mcleod he would not recommend useing his hyd. t.o. bearing in a street car. Also I believe Tilton offers bearings to suit a number of different styles of clutches. Choose carefully.
Do you have room between the torque tube and the bellhousing to put in an adapter plate. On a 951 my measurements said there was not enough room, although I did have an automotive bellhousing of undetermined origin.
Rob |
jamez
PORSCHEV
Posted: Wed Mar 12, 2003 9:05 pm Post subject: |
Jamez......here is what I did to tackle that problem.......I too tried to use a camaro style bell housing....even cut out the firewall to make room for the HUMP...but it didn't work out too well for me so I switched to a 1994 chev truck bell housing. It uses a hydraulic slave as well...but it is angled down under the car on the passenger side completely out of the way....like it was made for the job. also for my adadter plate i went to a junk yard,,,,found an old 5 speed tranmission.......and i literally cut the front of the tranny off with a zip wheel so all i had left was a flat plate that matched all the blot pattern for the chevy bell housing. this will help you getting the 'adapter' centered to the bell housing. The next thing you are going to notice is the factthat your 'drive shaft or pilot shatft' is too short to protrude out far enough into the pilot bearing. That can be addressed by two ways......you can have the tourbue tube stortened by the difference (10cm) if I recall right. or you have have to put a shaft extension..I wouldn't go that way tho...i don't think there would be enough spline to allow the clutch to move properly. I had pics of all this stuff....but my wife formatted the computer and deleted all my pics...now everything is in the car..THANKS BABE The draw back to shortening the torque tube is The cost (machine shop time) it puts the bell housing very close to the firewall. but give you good room up front!! I will aslo tell you that I had my drive shatt modified also.........but I could have changed the center of the clutch as well. I had the porsche splines cut off a flange welded on with four blot holes that bolt on a flanged chev input shaft..I admit this will be the weak point of the sytem...better here than the tranny I say. ...Well there...thats the way I tackled that problem........seems I have come soooo far....but have soooo far to go yet.
Good Luck _________________ 1976 924
jamez
Posted: Thu Mar 13, 2003 3:28 am Post subject: |
hey thanks for the input.. I like the idea of cutting off the front of the tranny, i might look into that.. what I was planning on doing with the drive line was to bring it into the driveline shop and have them weld a chevy spline onto it, and also make it protrude the right length and everything, I think they can do this, I have had them shorten drivelines for me in the past (not a porsche driveline).. I think i will try the hydraulic T.O. bearing, although i am a little worried about it.. for example, if it ever fails (which it will someday) I will have to take everything apart. also I guess they are difficult to get set up right. but the plus side is that i can just remove the clutch fork and cut off the part of the bellhousing thats in the way..
Porschev, were you able to keep power brakes? I know the renegade kit does away with them, from the measurements i have taken I think I will have to take the brake booster off too, but Im not sure yet.... also, how much of a problem was the cross member and sway bar? thanks for the help |
beario
Joined: 03 Nov 2002 Posts: 139 Location: st albans/cornwall
Posted: Thu Mar 13, 2003 4:57 am Post subject: v8 conversions |
hey guys,sounds interesting what you have done,i use the 944 lsd turbo box and torque tube with a custom made cold drawn steel shaft,identical to the original just about 1 inch longer to fit inside the rover cranshaft snuggly,also used the rover bell housing cut the back of it and mounted it to the porsche t.tube....p.s if you know anyone who wants to do a rover conversion i ha a full kit for sale 2 manifolds,1 lightened ali flywheel porsche with rover crankshaft bolt pattern,1 brand new sachs spring plate clutch kit,2 motor mounts,1 conversion plate that mounts rover to porsche t.tube had in my car for a while...changing conversion so hence for sale....  _________________ theres no replacment for displacement....V8 |
