required amperage on the cooling fan
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    924Board.org Forum Index -> Posts Rescued From the Old Board
Guest
PostPosted: Sun Jul 22, 2001 11:21 pm    Post subject: Reply with quote
Email: porsche
Date: 22 Jul 2001
Time: 23:21:29
Ok lets see does the stock fan run on a required amperage like will it burn out if its hot wired with a inline switch if so I could use a specific guage wire to deliver the correct amperage right
they get to hot directly wired Im not worried
Ill check the haynes guide electrical chart it might tell me something. I replaced the thermal time switch 1 but it got hot last summer when i got the brake system done with a new master cylinder and rear brake cylinders along with the ta radials since then the fan isnt right so i hot wired it and burned up 1 fan and got another now this 1s acting up i didnt look at it today i should be doin it right now
Guest
PostPosted: Mon Jul 23, 2001 2:38 am    Post subject: Reply with quote
Email: ballison@vt.edu
Date: 23 Jul 2001
Time: 02:38:26
Joe,
Amperage is a function of load. You can hook the fan straight up to the battery, it will only draw as many amps as it needs.
Ben
Guest
PostPosted: Mon Jul 23, 2001 6:42 pm    Post subject: Reply with quote
Email: ***************
Date: 23 Jul 2001
Time: 18:42:43
and all it was ...ground from switch was loose
this is in the dash or under it /toggle type
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    924Board.org Forum Index -> Posts Rescued From the Old Board All times are GMT + 10 Hours
