Ok lets see does the stock fan run on a required amperage like will it burn out if its hot wired with a inline switch if so I could use a specific guage wire to deliver the correct amperage right
they get to hot directly wired Im not worried
Ill check the haynes guide electrical chart it might tell me something. I replaced the thermal time switch 1 but it got hot last summer when i got the brake system done with a new master cylinder and rear brake cylinders along with the ta radials since then the fan isnt right so i hot wired it and burned up 1 fan and got another now this 1s acting up i didnt look at it today i should be doin it right now
