924ttrouble
Joined: 27 Feb 2003 Posts: 59 Location: Lacey, Washington
Posted: Wed Mar 05, 2003 11:57 am Post subject: unknown item |
| What is this item located on the driver side fender in the engine compartment toward the middle with a part number 477.957.901c? The item is square and has a cable on the top one on the bottom and an electric plug on the bottom. Does any one know? |
Posted: Wed Mar 05, 2003 2:21 pm Post subject: |
That should be the mileage counter for the oxygen sensor light. It just counts off a certain number of miles then closes a switch to light the light in the dash, then you're supposed to replace the oxygen sensor. Them's speedo cables going to and from it. When it's time for a new cable, most get rid of that setup and go with a single longer cable instead - cheaper, easier and way more sane. _________________ "..it's made in Germany. You know the Germans always make good stuff."
924ttrouble
Posted: Thu Mar 06, 2003 11:08 am Post subject: |
| Thanks for the info, I'm going to try to find the shop manual for this car. |
