What doesn't work from this brake MC rebuild kit?
Goto page Previous  1, 2, 3  Next
PopUpProject
PostPosted: Sun Dec 21, 2025 8:25 am    Post subject: Reply with quote
924RACR wrote:
And make sure, for that final squirt, that you close the bleeder off while the pedal's still dropping/caliper is under pressure...
Good to know, thank you!!! I'm obviously very new to all of this, but we're slowly getting it all figured out
Just trying my best to figure this out without total failure
Poppy the '82 924 Resurrection in Progress
PopUpProject
PostPosted: Sun Dec 28, 2025 12:56 pm    Post subject: Reply with quote
Raize wrote:
Just when you're pushing on it.
Keep hard pressure on it for a minute or two. If there's a nick on the master cyclinder bore, or a slightly torn seal, the fluid will slowly get pushed past that and you'll eventually push the pedal right down to the carpet.
But if it's just some air you're compressing, it'll not move any further.
Alrighty, I held full pressure on the brakes for 5 minutes and the pedal did not fall to the floor or fall beyond the what I think is the normal stopping point. Our buddies lift is currently occupied so we weren't able to throw her in air jail tonight.
When we get around to having her in air jail, if I crack the lines off and I'm not getting good streams off the mc, what could be going wrong? Or on the flip side, if we do get good streams off the mc, would that point to the hose lines being gunked up?
PostPosted: Sun Dec 28, 2025 10:36 pm    Post subject: Reply with quote
If you're not getting good streams from the ports of the master - then yeah, time to investigate/rebuild/replace the master. But I'll be surprised at this point if that is the outcome.
Yes, if you are getting good streams directly from the master ports, there must be an obstruction in the hoses or lines. Next step would be to take the hoses and lines apart (starting at the wheel end, with the hose) until you've gotten the blocked component off and can get a good stream again...
chuck21401
PostPosted: Sun Jan 04, 2026 4:00 am    Post subject: Reply with quote
The brakes in my car didn't feel quite right after a hard stop. I checked the brake fluid reservoir and it was low...but couldn't find any signs of leaking brake fluid from the brakes or the hydraulic clutch system.
Added fluid and went for a quick drive...same symptoms. I figured the brake MC was going bad but the missing fluid was a mystery. Ran some searches here...sometimes when the seals go the brake fluid ends up pooled in the brake booster. Pulled everything apart...sure enough...that's where it went. What a mass. Cleaned everything up, installed a new/re-manufactured brake master cylinder, bled the brakes...and was back on the road.
PopUpProject
PostPosted: Sun Mar 08, 2026 11:54 pm    Post subject: Reply with quote
Alrighty I am back with some more findings, we haven't pulled the lines or hoses yet, but there is a slow seep between the mc and the brake booster, which leads me to believe at a minimum that seal is bad between the two but could that be a sign of a bigger problem with the mc or brake booster?
PopUpProject
PostPosted: Sat Mar 28, 2026 12:23 pm    Post subject: Reply with quote
I have gone dumpster diving in the depths on here for more info on the mc, and along the way I managed to find a PDF of the Porsche Workshop manual, and the absolute rage of all there being on the mc was "replace mc". I was hoping there would be some tips on rebuild or further troubleshooting -.-
We have determined it is almost 95% certainly the mc. Yippee. not.
Although we mostly determined its a large risk trying the rebuild kit from pelican, I am still tempted to try it. However at that point, am I better off attempting to find a shop that could do a rebuild, sacrificing a matching one that I find on fbmp for dirt cheap to a shop, piecing together a kit from Pelican and where ever else I can find, or attempting to use a more modern MC and booster?
An oem from porsche is out of the question budget wise and online/ebay has not been much cheaper unless I want to risk it for the biscuit overseas.
PostPosted: Sat Mar 28, 2026 9:43 pm    Post subject: Reply with quote
Well, I mean all a rebuild encompasses is replacing seals, cleaning, and hopefully no corrosion to deal with (which would require at a minimum re-honing the bore, possibly replacing the piston if damaged)... if you got the kit and found it had correct replacements for the seals in yours, then you should be in business.
In my mind, it's really just a question of if you're willing to gamble the cost of the kit...
PopUpProject
PostPosted: Thu Apr 02, 2026 11:39 am    Post subject: Reply with quote
Yeah and the fun would be finding a shop that would be able to rehone everything if it needed it (which with my luck, it probably does) I do have plans of one day swapping to a 5 lug to have more modern brakes. Would it make sense to maybe go to a 944 mc and booster even though I am staying 4 lug for the foreseeable future, as I'm assuming they have more availability (and hopefully maybe cheaper)?
PostPosted: Thu Apr 02, 2026 8:40 pm    Post subject: Reply with quote
You can get a brake hone for your drill at a decent auto parts store! Easy-peasy...
MikeJinCO
PostPosted: Thu Apr 02, 2026 10:32 pm    Post subject: Reply with quote
The differing rod lengths between the 944 and 924 master cylinder and booster make it a swap requiring fabricated spacers. If you try to use the 944 booster it interferes with the throttle cable location coming thru the firewall.
Mike
'67 MG Midget Dp
PopUpProject
PostPosted: Fri Apr 03, 2026 7:35 am    Post subject: Reply with quote
I can barely draw a straight line, I'm not sure how successful I would be at honing everything out properly XD But it is worth a shot. I might try and build my own rebuild kit from Pelican and see what the individual items vs the 928 kit on there would cost, if I can get all of the little bits.
PopUpProject
PostPosted: Fri Apr 03, 2026 7:36 am    Post subject: Reply with quote
Good to know!!! Thank you, I hadn't fully explored that rabbit hole yet, it was more of just a thought as I've been going through the rolladex of options
PostPosted: Fri Apr 03, 2026 9:21 pm    Post subject: Reply with quote
I guess it's a good thing the hone is flexible and self-aligning, then...
https://www.autozone.com/p/duralast-brake-cylinder-hone-82-002/1266662
PopUpProject
PostPosted: Mon May 04, 2026 12:17 pm    Post subject: Reply with quote
GUYS WE HAVE BRAKES DOING BRAKE THINGS!!!!!!!!!!!!!!!!!!!!!!!
A miracle has occurred and we were able to find a "tested good" booster and mc out of an 82 for a very good price but unseen. Turns out the booster was bad, didn't hold vacuum, but the mc was good!!!! We swapped over the mc, remade the rear lines from the hoses to the drums, adjusted the shoes, and went to bleed the lines and we have normal bleeding! The wheels also finally stop now when she's in air jail and we can't free spin them anymore when the pedal is pushed. We still need to throw the wheels back on and see if the brakes actually stop the car now on the ground, but that'll happen when it is time for her to be out of air jail this week
Progress is happening!!!
SPLIFFMEISTER
PostPosted: Mon May 04, 2026 10:18 pm    Post subject: Reply with quote
Does it physicaly fit the existing mounting points and work ok though ? For those of us with the steering wheel on the right swapping in a complete 944 master and servo might be an option as they are much easier to find in the UK
Nick
Page 2 of 3
