daniel
Posted: Sun Jun 29, 2025 9:11 am Post subject: Improved engine and gearbox mounts |
Hi All,
I am wanting to replace the engine and gearbox mounts on my 77 race car (with getrag gearbox). The standard mounts are totally flogged out to the point where I am now missing gears occasionally (definitely NOT my driving ability
I am aware of the vibra technics engine mounts though I can't find anything for the gearbox. Looking at the existing mounts it looks very easy to weld in some 3mm plate once the rubber is removed and convert them to solid however I am concerned with cracking the gearbox casing, especially is there is some give with the engine mounts but not the gear box mounts.
Thankyou in advance for your suggestions!
Daniel _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
peterld
Joined: 10 Dec 2006 Posts: 987 Location: Noosa Heads QLD Australia
Posted: Tue Jul 01, 2025 8:48 pm Post subject: |
Hi Daniel
Can't really answer your question re the gearbox mounts. I simply ran what was there, albeit new ones at the time. For the engine, at the time we simply filled them with mastic until more recently when the vibra technics became available.
Wasn't 'Kondzi' (Konrad) from Poland, here on the Board, making alloy gearbox mounts? Do a search.
Incidentally, after 30 years my 932 is going back to a road car and I have available some of those English engine mounts.
Also ask the question on the Facebook forum
Porsche 924/944/968 for race cars ONLY (no road car content)
These are serious racers mostly from UK and USA. _________________ 80/81 932/8 ROW |
Raize
Posted: Wed Jul 02, 2025 3:09 am Post subject: |
I filled my gearbox mounts up with polyurethane. It isn’t adhered but it stays in and seem to do the job.
The engine and gearbox are basically one huge solid unit because of the torque tube so not sure solid mounts would ever be an option really. |
Karlio
Posted: Wed Jul 02, 2025 8:35 am Post subject: |
| VW passat gearbox mounts can be made to fit with a little bit of fettling |
