CS Head Build - Bigger Lighter Valves - Process - Progress
Goto page Previous  1, 2, 3 ... , 25, 26, 27  Next
Mike9311
PostPosted: Fri Aug 09, 2024 11:35 pm    Post subject: Reply with quote
Mclaren924 wrote:
any news on the insanity?
Yes, ramping up again after a bit of a break (quite obvious break and I am sorry since I know how I would be watching someone else do this)
Between the thought of summer ending and another member of the board pushing me, I have been organizing and going for the final push. Its the same for the GTS console. Yet another member gave me the push and the help I needed. The original print is actually hanging in the car now and a tweaked version is a week or two away
back to the head, I have had a lot of time to think and dwell on my results so far which has been helpful.
Anyway, stay tuned, I promise an update super soon
1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
1982 931 wana-be GTR race car
Mclaren924
PostPosted: Sat Aug 10, 2024 2:43 am    Post subject: Reply with quote
Glad to hear it, spend way too long reading through all of this last night and while I can't hold a candle to your knowledge, I have a much better understanding of how I want my head to be setup if I did want to sink some money into it. It seems like those wanting to really push the hp number while looking for a better curve, would gain from the valve shift. Also seems like a much more inline intake manifold could save some heartache in a non stock manifold situation? I understand that the whole point of this project is the stock manifold constraint. Just my ignorant synopsis of your findings. Can't wait to see more mate! Don't worry we all need time off sometimes.
Topls82
PostPosted: Wed Nov 27, 2024 2:46 am    Post subject: Valves Reply with quote
Guys
Any update on final version
Thanks for all efforts
Mike9311
PostPosted: Mon Dec 02, 2024 1:49 am    Post subject: Reply with quote
I wasn't going to post yet but your timing is perfect.*
*Side note in all of this. Someone convince me to get a CAM too. I have been looking at CATCAMS since their dual pattern looks interesting. It would be great to favor the intake especially with what I mention below about exhaust valve. Its so much work to set up the proper valve lengths and get the lash right with the lash caps that the thought crossed my mind to get a cam.
Anyway back to question:
This was never finished but its in full swing right now. There have been several things holding me back one of which is a cnc issue since I wanted to cnc port the other intake ports (Down one axis on the machine). Working on that situation and its one of my biggest frustrations. When I have something in my head it eats at me to complete things the way I originally wanted. I should know better that it not how it works
There has been way too much time to think about everything done so far but its time. Can't wait for Morghen to show up again to comment on longest project ever If anything, Morghen is truly the inspirational push I need
One of my last tests was to back cut an intake valve to see if it improved off-the-seat flow. In this case it didn't. As of a few days ago new valves are on the way. One to replace the back cut valve I wasted on the test and four more just in case I want to do a second "simple" head.
All along my plan was to only do the very least to the exhaust side. The issue was the super alloy I chose only came in 38mm which I always thought I would machine down to 37 or 36. To save time and keep it simple for this one I will leave it at 38mm which leaves the size ratio similar and I don't think it will affect anything in a major way. The previous owner of the head had done some port clean up and I am not going to do anything but clean up the new seat install. Keep it Simple
One of the things I did was weld up the chamber to re-imagine the shape for better pressure recovery. In hindsight, this just added work and I should have kept it simple but now I will finish (seriously this time)
Working on cnc parameters for the chambers over our holiday break here in the US. Scanned the head and worked through the process to develop a CAD surface which was then 'simulation machined'. I could then lay that simulated chamber back over my scan mesh to see if anything needed fixing. This needs to get done so I can install the rest of the seats
The last pic is supposed to be a switching gif to show the over laid images but it doesn't work
1980 931 since 1989
PostPosted: Mon Dec 02, 2024 8:16 pm    Post subject: Reply with quote
I simulated a couple of thousands cam profiles when i had acess to that, the best ones always had more intake duration than exhaust duration, at least on my setup with the std log exhaust manifold. Though i never tested if it was correct or not, but a cam is definitely a good idea.
Nice to see the machinig process, my head only has some hand finishing of the combustion chamber, nothing as fancy
How will you find a good way to set references for CNCing the ports?, these castings dont really have laser precision in my experience
PostPosted: Mon Dec 02, 2024 8:37 pm    Post subject: Reply with quote
I'm happy to see that you're still going at it with the combustion chamber development.
This is real development, this is the truly difficult work and this is the kind of work that requires in depth understanding of the subject related phenomenon and mastering of the complex tools required to do even the basic work.
My hat is off sir!
I imagine referencing for the machining to be done using the valve stem holes/cylinders and the machined flat face for depth.
I'm done for the year with the big efforts, sending the last 10 kits of the year by Wednesday and then i'll just work on improvements, documentation and planning for next year now for my own stuff.
Mike9311
PostPosted: Tue Dec 03, 2024 12:29 am    Post subject: Reply with quote
Thanks guys, always appreciate the input and encouragement
As far as the cam, I am leaning toward the smaller of the two catcams turbo cams. Drove me crazy, Dutchpug never tried it in his crazy build. I am not really a fan of the wide LSA but its due to the dual pattern design so it intrigues me over all
That is correct, I do use the valve guide which was referenced by the tappet bore as well as the flat machined surfaces on the outside of the head. To extend the surface for a dial indicator, there is a plate (vice parallel they are called here). I can sweep back and forth on the machines X axis with the dial indicator on that plate (0.0001 inch resolution (0.00254mm)). This works very well along with the centering on a valve guide but there was a story to this as well
The plate can be seen in this part of the head scan
The old guides (installed by a previous owner) did not reference the tappet bores well. After the first round of guides were installed I dropped in exhaust valves from the tappet side. It was easy to see they were not centered and at an angle. New guides without holes were then installed in 7 of the 8 holes and then drilled / reamed while installed in the head
In the end , the centering is done from tappet bore but in a series of steps. For this head and probably from now on because I am paranoid
Bad One. Some didn't even go down into the bore.
Good one with pic at odd angle. Always hard with a phone. Side note: I just figured out how to post non-zoomed photos
1980 931 since 1989
Mike9311
PostPosted: Tue Dec 03, 2024 1:32 pm    Post subject: Reply with quote
You can really see what I am talking about with this view of a valve in the OEM guide and tappet hole on the NA head I tested. Better angled pic. If it looks good here after you do the guide then its right
1980 931 since 1989
Mike9311
PostPosted: Sat Dec 07, 2024 7:58 am    Post subject: Reply with quote
This really intrigues me. It must have done the same for Dutchpug and his insane NA Turbo build back in the day (sadness...miss those days )
Intake lift is around 0.8mm (0.0315") more intake lift all around (according to graph anyway). This head project as it stands right now, follows stock flow to about 4mm Lift and then starts flowing all the way to 175-178 with intake (without intake even more). Since the head keeps flowing upward with additional lift, it would grab a tad more cfm over the nose of the cam vs stock (tip of my hat to Gegge thinking No wonder he says lift is key). Just think of the area under the curve this adds in combo with the additional head flow. I think this would match nicely. Also have this vintage adjustable cam gear to install which I plan on copying in the near future. I like the vintage look. Cam is ground already a bit advanced, so straight up would also be the plan.
Sorry for my crude overlay graphics
1980 931 since 1989
PostPosted: Sun Dec 08, 2024 3:47 am    Post subject: Reply with quote
Crazy how that guide was so much off center
Mike9311
PostPosted: Sun Dec 08, 2024 1:48 pm    Post subject: Reply with quote
I don't think this is a "thing" for every head, just me getting screwed by previous head builder. I chose a head that someone worked on. They ported each port differently too. Of course by hand it would be different but so obvious by eye was crazy. Then they did this to the valve guides...
They punched it to get some sort of interference fit
I used a larger reamer to clean up the guide holes. Then made my custom guides. In particular the exhaust guides I finished completely only to wonder why the valves looked funny installed. This continued until I dropped the valve in from the tappet side (not sure why, I just did). It was then I realized the reamer followed their bad hole and the guides were at an angle relative to tappet bores.
I removed those bad guides and now drill/ream each one in place using the tappet hole as a guide. Pretty sure I had to redo the offset guides too because I made a precision pin in the guide holes as an alignment bar to sweep with the dial indicator. Its harder to install the guides without a mandrel hole but ok
So much nicer now using tappet holes as the reference. So yes, crazy indeed
1980 931 since 1989
Mike9311
PostPosted: Wed Dec 11, 2024 6:12 am    Post subject: Reply with quote
Updates
Cam ordered
Setting up new water cooled torch setup to finish head chambers. Very difficult to do without it since heat required creates opportunity for contamination from torch itself
1980 931 since 1989
Mike9311
PostPosted: Tue Dec 17, 2024 12:54 am    Post subject: Reply with quote
I have been steadily working on one version of the port, bringing it from scan to CAD as accurately as possible. Then I started simulating CNC machining the port. I spend all this time doing this and end up starting over to tweak it more in my favor. Could have used a couple more cross section curves in a key area. The port with the rings is actually a CAD surface within the scanned head. That surface is then brought into the CAM to simulate
1980 931 since 1989
fblade
PostPosted: Tue Dec 31, 2024 11:15 pm    Post subject: Reply with quote
Great work @Mike9311, looking forward to seeing the results
Mike9311
PostPosted: Fri Jan 31, 2025 6:02 am    Post subject: Reply with quote
Thank you!
Starting to get anxious to see results myself
This just arrived and I like Now I need to push!
1980 931 since 1989
Page 26 of 27
