Ignition Timing Map
Goto page Previous  1, 2
PostPosted: Sat Apr 27, 2024 11:32 pm    Post subject: Reply with quote
Actually I'd say #3 tends to be hottest, at least on my NA.
...and now you're seeing why we all like modern EFI...
Raize
PostPosted: Sun Apr 28, 2024 8:48 pm    Post subject: Reply with quote
My AFR curve on full (2 PSI at 2000 rising to 4 PSI at 6000) boost is 13.5 at 2000 RPM, 12.5 by 3000 RPM, then 11.8 from 4000 to 6000 RPM now.
It's not perfect but I'd say it's decent. I have added manually adjustable lower chamber pressure to the fuel distributor so I can increase/decrease the proportional fuel flow just by turning a knob.
Now that the fuel is sorted, I can try and add more timing.
PostPosted: Sun Apr 28, 2024 8:57 pm    Post subject: Reply with quote
Yeah, that's not too bad for CIS... I wouldn't mind a bit richer, to cover the low end of the RPM range, but agreed, should be decent to roll in timing...
Have fun!
PostPosted: Sun Apr 28, 2024 10:19 pm    Post subject: Reply with quote
Thats not bad att all, let it be as it is
Page 2 of 2
