Replacement Caliper Options
924-UK
PostPosted: Mon Jan 29, 2024 3:23 am    Post subject: Replacement Caliper Options Reply with quote
My front right caliper is seized. I could send it away for a refurb but wondered if there are any other options out there for the 4 stud cars?
I've read a couple of posts about a VW Passat caliper which bolts straight on but can't find a part number to try and source a pair.
I say this as the front left bleed nipple is totally rusted and I know that as soon as I try and bleed that side it will snap.
Any info would be much appreciated.
PostPosted: Mon Jan 29, 2024 4:54 am    Post subject: Reply with quote
I dont think there are any good options for simple replacement, at least not with the correct piston size. I think a rebuild shouldn't be that bad, most likely it will need a new piston(if its the piston that is stuck )on the stuck caliper. Used callipers is an option but those would be stupid to put on without a light refurb anyway.
safe
PostPosted: Mon Jan 29, 2024 6:36 pm    Post subject: Reply with quote
Rebuilding the calipers is pretty easy.
Push out the piston in the seized caliper while connected to the car, obviously without being mounted on the rotor. It can be difficult to remove them on the bench.
Bleeders could look horrible and not be stuck and the other way around, so it might be worth to put a wrench on it carefully.
Soaking rusty parts in an acid bath can free up rusty threads, and of cause rust everywhere else. I prefer Phosphoric acid in a ~20% solution. Pretty safe, won't burn of your skin if you get it on you, at least not immediately. Many use citric acid, haven't tried that, might just take a little longer time.
Obviously heat too...
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
PostPosted: Tue Jan 30, 2024 12:31 am    Post subject: Reply with quote
Contact Max at Frazerpart to see if he has any exchange calipers. Or you need to remove and send to Big Red or similar for refurb, or rebuild yourself
Highly recommend 924 owners club uk for your local questions. Theres people in your area that can assist for sure on resurrecting the car
Mkol
PostPosted: Wed Jan 31, 2024 8:42 am    Post subject: Reply with quote
Check out this thread, I had the similar issues a month or so ago and managed to get through it. The bleed nipple can be extracted with a bit of patience and a few tricks.
If you have the calliper of the car then the piston can be removed, try compressed air through the brake line inlet or if you don’t have a compressor then you can use a foot pump with a bit of creativity!
https://www.924board.org/viewtopic.php?t=46012
Goldwolf
PostPosted: Sat Mar 23, 2024 2:10 am    Post subject: Reply with quote
I'm late to the party but 91 Passat Calipers work.
I ordered Centric brand(PN# 14133030) 1991 Passat calipers for $36 each from rockauto.
I have failed to upload pics of them on the car, but they were direct bolt on. Other thread
https://www.924board.org/viewtopic.php?t=40924&postdays=0&postorder=asc&start=0
[/quote]
1981 Weissach Edition #179
Benino
PostPosted: Wed May 22, 2024 6:09 am    Post subject: Reply with quote
Can you provide any more details here? Did you use the stock 924 rotor and brake hoses? I guess you switched to 1991 Passat brake pads? Any difference in braking performance? Did it affect front/rear bias?
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
Karlio
PostPosted: Wed May 22, 2024 8:26 am    Post subject: Reply with quote
Might be missing something here but don't 1991 vw passat calipers use a 22mm thick disc?
Benino
PostPosted: Wed May 22, 2024 3:58 pm    Post subject: Reply with quote
I was wondering about that too. I saw the Passat used vented rotors
PostPosted: Wed May 22, 2024 5:34 pm    Post subject: Reply with quote
As far as I know these have larger pistons, thus longer braking distance due to shifting of the brake balance.
Benino
PostPosted: Thu May 23, 2024 6:38 am    Post subject: Reply with quote
I've actually always had too much rear bias on my car. Over the years I've replaced the wheel cylinders, the master cylinder and rebuild the calipers. No change. The rears always want to lock up first.
daniel
PostPosted: Thu May 23, 2024 9:17 am    Post subject: Reply with quote
I also use the VW/Audi calipers that are fitted to early 90's passats, A4's and similar. I use the standard 924 rotors and have found the rotors cope with the heat much better than with the smaller 924 pads and calipers. I used high grade steel washers to space the calipers axially and keep an eye in the pads as you can't wear them all the way down.
1989 944 Cabriolet
Goldwolf
PostPosted: Wed Jul 31, 2024 2:02 am    Post subject: Reply with quote
Stock everything,pads and calipers from the Passat
