ChrisMadge
Posted: Fri Sep 23, 2022 4:42 pm Post subject: |
| Carrera RSR wrote: | Anyone have any idea if the KAE 3.300.300 relay has any kind of rev limiting feature? I have this relay in my car and just thinking aloud of something I have experienced
FYI this KAE relay on my car primes the pump most times I turn the ignition to on. On cold start ups I tend to turn a few times to hear the pump prime a few times and then it starts on first kick of the start (without the need of 5th injector connected ) If I don't prime it takes 2-3 cranks more for the fuel to reach pressure and fire up. |
Hi Steve
Without the 5th injector, where does that initial enrichment come from for cold starts? _________________ 1984 MY 924 2.0 NA
1975 MG Midget |
Posted: Fri Sep 23, 2022 6:53 pm Post subject: |
| ChrisMadge wrote: | | Carrera RSR wrote: | Anyone have any idea if the KAE 3.300.300 relay has any kind of rev limiting feature? I have this relay in my car and just thinking aloud of something I have experienced
Hi Steve
Without the 5th injector, where does that initial enrichment come from for cold starts? |
Not needed on mine since the engine rebuild as there's too much fuel with 5th injector connected. Starts better and more consistently without. Same with modified Escort RS turbos back in the day, they often have the 5th disconnected for same reasons. Just need a 100% maintained fuel system _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Beartooth
Posted: Mon Oct 03, 2022 3:36 pm Post subject: |
I think I might have a solution. Not plug and play, but looks like one that would only require minor modifications. I noticed that some of the later VW K-jet relays are still available. The versions in question would be KAE 3.300.210/220/230. Those will not plug into a 924: the pinout is different, except 30 and 87, but those pins are significantly bigger. Still, out of curiosity, I bought one off RockAuto (WVE branded that turned out to be KAE). It seems to make it work, I'd have to trim down the sides of terminals 30 and 87, and rework the socket. It appears pin 15 [ground] swaps sides, pin 31 [to overboost switch for turbos; to ground on others?] takes its place, and pin 1 [coil terminal 1] either gets moved to the bottom left or wired externally. If there were some way to getting the socket for the VW relay, that would probably make things easier, but I'm guessing it's part of a relay block and not something you could separate. One other option - possibly - is to de-solder the main circuit board and solder it to the base of the original relay. Internally, the relay is two circuit boards in an L shape, with the base of it just making up the male end of the socket, which may or may not be easily grafted to the original relay. My car had no relay when I got it, so I've only got what I can find online and what's in the Haynes manual to go off of.
There are some advantages to the VW relays: similar to the 928 relay Eliza mentioned, they have a "prime" feature, and *may* have a rev limiter. I'm going off this information sheet someone put together: http://www.cabby-info.com/Files/Relays_Kjetronic.pdf. Also, notice that you'll probably want to avoid the KAE 3.300.220/230 relays as some circuit boards are defective and may not work properly or at all. I popped mine apart, and of course it's one of the affected boards. Apparently, the KAE 3.300.210 (used in 83-87 1.8L VWs) won't have one of the defective boards. The rev limiter seems a little fuzzier, unfortunately. That pump relay guide indicates that some VWs had a limiter built into the rotor, and may not have had a limiter in the relay. The 3.300.210 relay, assuming it has a limiter, is probably going to cut out between 7500 and 8000. So maybe not that useful (not sure where our motors start to come apart). The later relays are lower (6500 for the .230), but again, there's a batch of those out there that are defective. Anyway, I'm going to give the relay I've got a try; hopefully I don't run into any big issues getting the wiring set up. I think before I adjust any wiring in the car itself, I'll make some jumper wires and just see if it'll work. If I make any progress, I'll update as I go. _________________ 1980 931 diamond in the rough |
Riggard
Joined: 16 Feb 2021 Posts: 90 Location: Heemskerk, Netherlands
Posted: Wed Oct 05, 2022 5:15 am Post subject: |
Sounds good! keep us posted about the journey, I'm curious.
I don't know the exact available space available, but I could also imagine 3d printing an 'adapter plate' where you basically plug in the new relay and re-route the wires to the 924 pinning. Kind of like your Jumper solution, but a bit more robust. |
Yannick931
Posted: Mon Sep 11, 2023 5:48 pm Post subject: |
| Eliza wrote: | ...
I was lucky ( prudent? ) enough to stock a few when they were still available, although I switched to a KAE 3.308.200 ( 92861511301 ) from a K-Jet 928 because that is a direct fit AND consistently primes the pump for a second or two at ignition-on. This makes the car start at the first turn of the key, every time. Brilliant. These are still occasionally for sale at ridiculous prices.
Eliza |
Hello my name is Yannick, I am from germany and own a 931 S2.
I am also searching for a new fuel pump relay. As Eliza said is it possible to use the 92861511301 relay instead of 433906059 ?
I would be very happy if this will work. |
bear924
Joined: 26 Jul 2005 Posts: 95 Location: South West Queensland, Australia
Posted: Sat Nov 11, 2023 10:24 pm Post subject: |
A little while ago I have away my spare fuel relay to resurrect someone's 924 and have been searching for a new spare since then. Today I tried a 92861511301 and it worked fine ... plug in, no mods required.
I purchased this from Design911 (no affiliation) for 50 pound ... seems they have a supplier who is making these now. I couldn't find a 924 or 928 relay elsewhere without spending silly $$$ on a used one.
So in short... if you need a relay, Design 911 has the 928 one at a reasonable price. |
