Need some help for porting the intake port in 964
Goto page Previous  1, 2, 3, 4
kondzi
PostPosted: Wed Jul 12, 2023 6:34 pm    Post subject: Reply with quote
Would be nice to scan these in 3D and try to arrange one on the other in CAD software to see where the differences are. Unfortunately I don't have access to a 3D scanner and none anywhere nearby commercially available as I was checking. I don't want to send those though, being afraid I will lose my only mold I have
Konrad
'89 951 US
'88 Mustang 5.0 LX Convertible (factory specs)
'84 911 Carrera 3.2 RoW (factory specs)
'81 931 RoW (TBD)
'81 Ford Capri 2.8i (factory specs)
'79 Ford Capri 2.9 (heavily modded)
PostPosted: Wed Jul 12, 2023 6:42 pm    Post subject: Reply with quote
If you want, you can send them to me, i'll scan them for you and send them back.
Mike9311
PostPosted: Thu Jul 13, 2023 7:46 am    Post subject: Reply with quote
Morghen, maybe you can lend your input to this thought. Maybe he is missing the fin in the final cnc version because of the conversion from scan to a surface in the CAD software? The scan has such finite detail which then gets smoothed out when converting. Then, in a much smaller way, you have both the CNC software as well as the cnc itself 'smoothing' the tool path while following the surface within a specified tolerance
This is the issue I have been having myself as I convert the port from scan data to a surface.
1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
1982 931 wana-be GTR race car
PostPosted: Thu Jul 13, 2023 5:10 pm    Post subject: Reply with quote
Data conversion algorithms will always have an impact on actual values.
Generally i avoid using convertors, whatever i scan, i re-design myself by hand "under" the scanned surface. This gives me greater control over the resulting geometry but of course it takes a lot of time.
So if there is a mistake, i made it, not the software.
Mike9311
PostPosted: Fri Jul 14, 2023 11:19 pm    Post subject: Reply with quote
Nice, I know how that goes!
1980 931 since 1989
kondzi
PostPosted: Sun Jul 16, 2023 5:34 am    Post subject: Reply with quote
Thanks Ciprian, what I’m afraid is the courier losing the package
Currently I can live without the scan. I got the STP file though. But I only have a viewer. Can this step file be converted to something more useful?
Konrad
'89 951 US
'81 931 RoW (TBD)
PostPosted: Mon Jul 17, 2023 4:33 pm    Post subject: Reply with quote
Yes it can.
kondzi
PostPosted: Wed Jul 19, 2023 7:58 am    Post subject: Reply with quote
Guys I discovered something nice today
I was resurfacing the heads on my lathe, and after that, cleaning the heads to prepare them for assembly in some time. As I was paying attention to get all that hair size aluminium leftovers removed, I discovered the seat, that was a 3-angle cut by factory, is no longer 3-angle seat. Now it's radius cut!
That could explain those few CFMs over my hand ported job results on flow bench, right?
Konrad
'89 951 US
'81 931 RoW (TBD)
kondzi
PostPosted: Sat Oct 19, 2024 9:30 pm    Post subject: Reply with quote
Darn, how much I missed, No time to go through all of that.
But Anyway, yesterday it was dyno tuning day for the car with the above mentioned heads.
I got 320HP and 380Nm. I’m very pleased with the results (70HP gain and 70Nm gain over stock engine).
Will try to attach the dyno chart later.
Have a nice WE guys
Konrad
'89 951 US
'81 931 RoW (TBD)
Page 4 of 4
