safe
Posted: Tue Feb 14, 2023 3:08 am Post subject: My "Rat rod" 924 NA turbo conversion. |
I haven't written much about my car, a 1979 NA. I found it really cheap (almost free) in very bad condition.
Welded up the bad rust, floor, rockers, battery box, rear wheel tubs, spare wheel tub, front inner fenders. Basically the whole car. Just for kicks.
Then I read about "Project Black" and got a bit inspired...
Fabricated a turbo kit, converted to EFI, "rebuilt" the engine.
Then I headed to the dyno (last spring), it was both a success and somewhat of a let down.
The good thing was that it ran flawless up to 1 bar on regular pump gas.
The bad was that above 1 bar the clutch slipped so I could't go higher , I was planing on using E85 above 1.2 or something like that.
It made 236 hp and 330 Nm at the wheels. 330 was pretty good for that clutch since it was only speced for 300Nm as I gathered later. Last week I upgraded the clutch to one rated at 500 Nm.
At the current power and boost level I'm just into the efficiency of the compressor, can push it above 2 bar with no issue, probably closer to 3, but I'm not desperate to destroy the engine and transmission....
When the weather and roads gets better I'm going to brake-in the new clutch and head back to the dyno. I'm really curious how far a stock engine can be pushed!
Its pretty fun to drive as is, really scoots when the turbo comes in above 3000 and makes cool noises when you let of the throttle!
Stock NA engine internals with the exception of:
*An NA-performance cam, not sure that does anything good in a boosted application.
*Slightly ported head, a "cleanup" I would call it.
*Larger ring gap.
To bad I don't have a way of attaching pictures here.
Very short and bad video from the dyno: https://youtu.be/x5Icr_Dit9E
There is some pictures here: https://www.instagram.com/the924rat/ _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe |
kondzi
Posted: Tue Feb 14, 2023 7:59 am Post subject: |
Cool. What ECU do you run? Any fancy sensors (knock, FlexFuel, as you mentioned E85, others?), or just old school bare minimum to run it?
Stock pistons? Which CR? _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Posted: Tue Feb 14, 2023 8:30 am Post subject: |
Finally , i know there are a bunch of people interested in this build, maybe because i mentioned it. Though some Images would probably be nice for people who doesn't know the car details  _________________ 1980 924 Turbo
safe
Posted: Tue Feb 14, 2023 5:26 pm Post subject: |
| kondzi wrote: | Cool. What ECU do you run? Any fancy sensors (knock, FlexFuel, as you mentioned E85, others?), or just old school bare minimum to run it?
Stock pistons? Which CR? |
Maxxecu Street, a really competent system for reasonable money. In hindsight I should have gone for the bigger Sport or Race version. I'm lacking in mainly inputs, that could be solved by a can bus extension.
No knock-sensor, the "Race version" has knock capability. But I was expecting to use E85 so knock isn't an issue at all.
I got a flexfuel sensor, not sure if I'm going to use that for the tuning, its quite a lot of work to get it right according to my tuner and for little use.
Just wideband o2 and one egt sensor, oil pressure and oil temp.
I would like to add more stuff like fuel pressure, air temp pre intercooler etc. Inputs for boost maps, anti lag etc.
I have launch control so I can leave under boost.
Yes, stock pistons at stock CR.
The system is pretty basic and I have been cheap where possible, but its never going to be cheap....
I've spent on the ECU, the turbo (Borg Warner S200 SX-E 7070 S252 0.63) and the fuel lines. I have almost only PTFE AN fuel lines and metal lines under the car.
Huge (600x300x76 mm) cheap china intercooler in the front. _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
safe
Posted: Tue Feb 14, 2023 5:28 pm Post subject: |
| Cedric wrote: | Finally , i know there are a bunch of people interested in this build, maybe because i mentioned it. Though some Images would probably be nice for people who doesn't know the car details  |
Need to find a some free image hosting I guess.... _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
Posted: Tue Feb 14, 2023 5:47 pm Post subject: |
| safe wrote: | | Cedric wrote: | Finally , i know there are a bunch of people interested in this build, maybe because i mentioned it. Though some Images would probably be nice for people who doesn't know the car details  |
Need to find a some free image hosting I guess.... |
Sometimes i use my rejsa.nu uploaded pics on here or imgbb. com for example, though the long term future is always uncertain for free upload hosts. _________________ 1980 924 Turbo
safe
Posted: Tue Feb 14, 2023 7:24 pm Post subject: |
Trying imgur hosting....
Porsche 931 -79
safe
Posted: Tue Feb 14, 2023 7:33 pm Post subject: |
Engine bay:
Starting point, doesn't look to bad here actually:
Dyno papper, wheel hp and torque:
Porsche 931 -79
safe
Posted: Tue Feb 14, 2023 7:43 pm Post subject: |
Lots of this around the car:
Engine bay as it was (I got it working with k-jet):
Porsche 931 -79
safe
Posted: Tue Feb 14, 2023 7:48 pm Post subject: |
Interiour:
I didn't think that would cut it so had a custom one made with factory fabric.
The center console is getting the same tartan instead of the tan in the picture as I type this.
Porsche 931 -79
Posted: Tue Feb 14, 2023 9:45 pm Post subject: |
Dash and seats were somewhat decent
Cool build, nice to see another effort to push the standard engine.
So about 110 extra HP for 1bar of manifold pressure.
Pretty damn good if you look at it from percentage point of view, you nearly doubled the performance of the european 924. _________________ Supercharger and EFI kits
safe
Posted: Tue Feb 14, 2023 10:26 pm Post subject: |
| morghen wrote: |
More, this is wheel hp. The tuner (Martin Lundkvist @ Luntec) guesstimated it to 270ish crank based on the difference he used to see between his engine dyno and this hub dyno.
He had 2 engine dynos inside the shop, the big one capable of 4000hp. He was/is a drag racer and did a lot of tuning on his and other cars. He mentioned being being first over 400 km/h in his class, or something like that. Volvo was a specialty of his, porting, grinding his own cams. I was really impressed by this guy.
I had a 951 before with 290ish hp, probably more as it had no boost control. This 924 feels very near to that. I don't doubt that it has 270 on the crank. _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
Posted: Tue Feb 14, 2023 11:28 pm Post subject: |
Just looked up the golf 7 gti, makes 230hp at the crank at 1.2bar
So the 924 NA engine at 1bar makes 270 at the crank.
I suspect that the emissions standards that the new cars have to meet sap so much power but still, the 924 is damn good, even today. _________________ Supercharger and EFI kits
madislandguy
Joined: 25 Nov 2009 Posts: 38 Location: Madeline Island, WI and Elburn IL
Posted: Wed Feb 15, 2023 12:25 am Post subject: |
| What's the story on the white steel wheels? They look really cool. |
safe
Posted: Wed Feb 15, 2023 12:31 am Post subject: |
| madislandguy wrote: | | What's the story on the white steel wheels? They look really cool. |
Citroen C5 I think, don't remember. 16x7" (Made by Michelin), media blasted and powder coated. I have some gold alloys also.
I have a contact that helps me with powder coating. The entire suspension and stuff have been media blasted and powder coated. Except the front struts that will be changed for Gaz struts when the time comes. _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
