chardorcher
Posted: Sun Jan 29, 2023 12:48 am Post subject: Fuel pump wires |
There are 2 wires at the rear which connect to the pump, a brown and black one, Am I correct to say that the Brown is positive? Also why does the pump still seem to turn when bench tested and wires are altered around? Thanks guys. _________________ MANY CARS |
Joined: 29 Jul 2001 Posts: 9073 Location: Royal Oak, MI, USA
Posted: Sun Jan 29, 2023 10:16 pm Post subject: |
No, brown is basically always ground on German cars.
Don't forget to check your grounds... _________________ Vaughan Scott
chardorcher
Posted: Mon Jan 30, 2023 9:09 pm Post subject: |
| 924RACR wrote: | No, brown is basically always ground on German cars.
Don't forget to check your grounds... |
Thanks my friend, a friend of mine suggested an extra strap from the engine block to the chassis/body, I guess this will do, as for other earths we have thoroughly cleaned and changed any loose connections, wires etc. Still more work to do.... _________________ MANY CARS |
