Engine skipping and stalling on acceleration
BWW
PostPosted: Fri Aug 26, 2022 10:43 am    Post subject: Engine skipping and stalling on acceleration Reply with quote
I set my timing today using Smoothie's very helpful guide (https://www.924board.org/viewtopic.php?t=18355). But when I open the throttle, the engine, skips, sputters, dies, etc. I know there are many possible causes for this, but is there somewhere in particular I should start? Vacuum leaks? Air-fuel mixture? Thanks!
Brent
'81 931 project car
Mike9311
PostPosted: Fri Aug 26, 2022 11:44 pm    Post subject: Reply with quote
vacuum leaks are easy to check so if it idles, just spray brake clean around suspected areas with care. If idle changes due to spray that is you leak.
1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
1982 931 wana-be GTR race car
BWW
PostPosted: Sat Aug 27, 2022 2:47 am    Post subject: Reply with quote
Good advice. Thanks, Mike. I will give this a try. I should also mention that there's a clinking/pinging sound coming from the throttle body (I think) when I give it gas. This might be relevant? The video shows what I'm talking about. Thanks again!
https://isu.box.com/s/21ewd0zweqvsd1jf5zjfzs95ug0bd4xo
Brent
'81 931 project car
BWW
PostPosted: Tue Aug 30, 2022 7:19 am    Post subject: Reply with quote
I'm following up on this on the off chance that it's useful to someone down the line. I tracked the source of the sound to somewhere in the CIS/k jetronic system. I'm thinking a rebuild might be necessary.
Brent
'81 931 project car
