using 931 head on NA bottom end
Goto page Previous  1, 2, 3
PostPosted: Thu Mar 25, 2021 10:14 pm    Post subject: Reply with quote
When I did my 931S2 pistons I had basically 0 deck clearance and had to cut pockets. From the clay marks they are a bit deeper than necessary.
https://imgur.com/d9R2u11
https://imgur.com/7WdNwaO
Mike
Juho
PostPosted: Thu Mar 25, 2021 11:20 pm    Post subject: Reply with quote
with na head?
PostPosted: Fri Mar 26, 2021 12:52 am    Post subject: Reply with quote
Yes, NA head
Mike
anthonimartini
PostPosted: Fri Mar 26, 2021 1:26 am    Post subject: Reply with quote
the s1 and s2 931 pistons have the same height correct? just a different bowl shape/volume? i have a nice set of s1 pistons i considered getting the ring lands machined to accept NA sized rings for reliability. i didnt consider using them for a bump in compression over the euro NA pistons. how much volume did those reliefs add to the chamber?
ive saved alot of 924's
current:
79 MochaSchwartz 931
83 944
87 924S
formerly known as turbellion, lost password.
safe
PostPosted: Fri Mar 26, 2021 1:31 am    Post subject: Reply with quote
Whats wrong with the turbo rings?
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
PostPosted: Fri Mar 26, 2021 5:06 am    Post subject: Reply with quote
They cost One Jillion Dollahs (per slug).
PostPosted: Fri Mar 26, 2021 5:20 am    Post subject: Reply with quote
Welcome to my world. I bought the pistons for about $100, by the time I bought the rings, had the pistons machined for the NA rings and then got the valve pockets cut I was within about $100 of just getting a set of new forged lightweight JE pistons with rings and pins.
Mike
anthonimartini
PostPosted: Fri Mar 26, 2021 7:58 am    Post subject: Reply with quote
and they break. at least under boost. i can get them machined to fit the larger rings and use a decent set of rings for about half the price of the oem sized rings. the are a bit more efficient then the NA rings as the thinner contact area reduces friction. but ill take the reliability.
current:
83 944
87 924S
dial67
PostPosted: Fri Aug 05, 2022 9:28 am    Post subject: VW Type 1 pistons Reply with quote
Did the VW pistons work well in your build? If so how much deck height? It would seem that the block would have to have considerable material removed. I am interested in using the VW pistons because they will be easy to source. I have had quite a run around trying to buy pistons.
Page 3 of 3
