924martinirossi
Joined: 04 Nov 2002 Posts: 605 Location: Seattle, Washington, USA
Posted: Tue May 13, 2003 4:32 pm Post subject: Hunting at Idle |
My car has been having some rather small problems with the idle staying at the correct setting. Yesterday the car started to idle from 1k - 1.2k just going up and down about every two seconds. Also sometimes when I would start the car I noticed that the tach would jump up and down. And finaly the car cut out while driving, however it restarted quickly.
Today I started it up and it died before I got out of the driveway. What I found was about 2vdc on terminal 15 of the coil, it should be a miniumn of 5. When I disconnected the Ignition Control Unit (ICU) the voltage went up to battery voltage. All wires and the coil pass the required tests and are good.
Anyone have a spare ICU to send me for a 81 931?
Fairchild p/n 211-905-351
Lucas p/n DAB400
Bosch p/n BIM 137
Porsche p/n 191.905.351A
Michael |
Posted: Tue May 13, 2003 11:14 pm Post subject: |
This sounds like it could be a mild case of the flakey 12 pin DITC connector problem. I'd try an unplug-replug on that connector. _________________ "..it's made in Germany. You know the Germans always make good stuff."
924martinirossi
Posted: Thu May 15, 2003 2:06 am Post subject: |
Just checked the connector of the DITC all looks good. Still no spark, tach signal or fuel pump relay action.
Michael |
Jim d
Posted: Sat Jun 04, 2022 12:23 pm Post subject: |
| 924martinirossi wrote: | Just checked the connector of the DITC all looks good. Still no spark, tach signal or fuel pump relay action.
Michael |
I found your post because my friend is having a similar issue. I know this was along time ago, but do remember what caused your issue? _________________ Jim delToro
1977 NA
CNY PCA member |
kondzi
Posted: Sat Jun 04, 2022 11:16 pm Post subject: |
Maybe faulty crankshaft position sensor? Do you have access to scope (best) or multimeter (set to AC) to see if the sensor produces alternating Signal? _________________ ---
Konrad
'89 951 US
'88 Mustang 5.0 LX Convertible (factory specs)
'84 911 Carrera 3.2 RoW (factory specs)
'81 931 RoW (TBD)
'81 Ford Capri 2.8i (factory specs)
'79 Ford Capri 2.9 (heavily modded) |
Fifty50Plus
Joined: 28 Feb 2008 Posts: 1422 Location: Washington DC area
Posted: Sun Jun 05, 2022 6:36 am Post subject: |
It's an NA? No crank sensor then. _________________ 1979 924 NA race car H-Prod SCCA
1982 924 NA race car - Sold
1981 924 Turbo sold
1982 924 Turbo sold
Posted: Sun Jun 05, 2022 8:12 am Post subject: |
Slow/lazy O2 sensor?
Use a dwell meter in 4cyl mode and see what duty cycle the frequency valve is running at, oscillating, hunting..
Black wire on test port drivers side fender well near firewall..
Or you could just unplug the O2 sensor and see if it stops hunting.. _________________ 80 Turbo - Slightly Modified |
