Alternator ground strap dumb question
Goldwolf
PostPosted: Sun May 15, 2022 12:12 am    Post subject: Alternator ground strap dumb question Reply with quote
I had my alternator rebuilt a couple months ago. Car has been great, wipers work and stop, park light goes off.
But now I have no charging again. Poking around found the ground strap broken. Dumb question is, this is my problem right? Change the wire and should be good?
1981 Weissach Edition #179
Goldwolf
PostPosted: Sun May 15, 2022 12:58 am    Post subject: Reply with quote
Voltage while running drops at the battery is my symptom. Battery loses voltage. So would this strap being broken cause the alternator to not charge or that strap just makes it more efficient?
I'm thinking the alternator rebuild failed, but maybe it's this ground.
I rebuilt the original alternator, it's not a reman.
PostPosted: Sun May 15, 2022 3:30 am    Post subject: Reply with quote
Alternator can’t charge if it has NO ground..
It’s mounted on runners mostly isn’t it?
Yea you NEED a ground strap/wire and it could definitely be the problem..
80 Turbo - Slightly Modified
Goldwolf
PostPosted: Sun May 15, 2022 4:03 am    Post subject: Reply with quote
Makes sense to me. There is current to that strap. Just didn't know if it grounded through another path. But that strap is there for a reason.
PostPosted: Sun May 15, 2022 11:07 am    Post subject: Reply with quote
With the rubber bushings on the alternator brackets a ground strap is required to complete the circuit.
Mike
Goldwolf
PostPosted: Mon May 16, 2022 9:50 pm    Post subject: Reply with quote
Thanks for the confirmation. Part ordered, now if I can contort myself to get it mounted
