Eliza
Joined: 17 Aug 2015 Posts: 174 Location: Prov. Utrecht, The Netherlands
Posted: Tue Apr 19, 2022 2:52 pm Post subject: DITC pressure line banjo bolt specs |
Hi all!
Is anyone with a series 2 turbo able to measure the banjo bolt that connects the pressure sensing line to the DITC? Overall length and thread length would be great.
I am planning to use a double banjo and additional nipple to connect my boost gauge control line directly at the DITC. Teeing into the pressure line ( 40-year old rubber ) seems a risk I'd rather not take.
Thanks in advance!
Eliza _________________ 1985 924 NA RoW
1981 931 S2 RoW |
kondzi
Posted: Tue Apr 19, 2022 6:06 pm Post subject: |
I'll check, should have my DITC somewhere on shelf in the garage. _________________ ---
Konrad
'89 951 US
'88 Mustang 5.0 LX Convertible (factory specs)
'84 911 Carrera 3.2 RoW (factory specs)
'81 931 RoW (TBD)
'81 Ford Capri 2.8i (factory specs)
'79 Ford Capri 2.9 (heavily modded) |
Eliza
Posted: Tue Apr 19, 2022 9:29 pm Post subject: |
Thanks a bunch, Konrad!  _________________ 1985 924 NA RoW
1981 931 S2 RoW |
Posted: Tue Apr 19, 2022 11:07 pm Post subject: |
The length is around 17mm long, and thread about 9mm  _________________ 1980 924 Turbo
kondzi
Posted: Wed Apr 20, 2022 4:02 am Post subject: |
Bolt is OD 8mm / ID 4mm with 8x1mm thread.
Bolt lenght (without 12mm wrench 6-side head) 17mm (21mm with head).
Bolt thread lenght ~9.8mm
Banjo connector ID 8.1mm
Banjo connector height 8.2mm
Banjo connector inlet ID 3mm
Banjo connector inlet smaller OD 4.5mm / bigger OD 5.5mm
Inlet length (for pipe) 15mm
HTH _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Eliza
Posted: Wed Apr 20, 2022 2:04 pm Post subject: |
Thanks for this!
You guys rock.
1981 931 S2 RoW |
kondzi
Posted: Wed Apr 20, 2022 10:58 pm Post subject: |
| Eliza wrote: | Thanks for this!
You guys rock.
Eliza |
You're just extremely lucky, that my DITC failed and I removed it in favour of MegaSquirt and did not throw it to the bin
Good luck  _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Eliza
Posted: Wed Apr 20, 2022 11:40 pm Post subject: |
If at any point you're looking to sell the DITC, do let me know.
I'd love to have a spare, just because and it may be repairable
Thanks again,
1981 931 S2 RoW |
kondzi
Posted: Thu Apr 21, 2022 5:13 am Post subject: |
Well in mine it seems DITC alone is fine, but the sensor failed... Or started failing when heating up. Repeatedly. So in the end failed. _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Eliza
Posted: Thu Apr 21, 2022 2:07 pm Post subject: |
Oh nice So, should you want to sell it, drop me a message and let me know what you'd like to have for it.
I believe that the only parts that ever break are the ones you have no replacement for. So I already have a collection of "insurance" spares, and I'd love to add the DITC
1981 931 S2 RoW |
