Portporschedon
Joined: 10 Aug 2006 Posts: 34 Location: West coast of Scotland
Posted: Wed Mar 09, 2022 6:35 am Post subject: |
had the identical problem.
Front wheel re-balance improved it, but not by much.
Full alignment check and another wheel re-balance by a Porsche dealer solved the issue.
Happy motoring
Don _________________ White 1983 924 - Renovated to near original condition and my daily driver
Dolomite 1986 924S - Coming to the end of a 4 year refurbishment.
Life is not a rehearsal |
bureau13
Joined: 07 Sep 2017 Posts: 496 Location: South Florida
Posted: Wed Mar 09, 2022 2:19 pm Post subject: |
Sorry, I wasn't clear...I feel it in the steering wheel. I don't know that wheels are actually doing anything, but my steering wheel shakes.
| kondzi wrote: | Wheel wobble can be caused by a lot of things.
For the steering shaft UJ, grab by hand the UJ and ask someone to move steering wheel slightly left-right-left-right... if there is movement, you need to replace UJ in the shaft. I doubt though it would cause wheel wobble. Mine needs replacement as well and I have not noticed it - wheel alignement (toe in) makes your wheel drive straight forward, at least it should (if not, do wheel alignement, or just do it anyway).
The other thing is brakes, slight friction, slightly bent discs could cause wheel wobbling as well. When you're doing 60 mph and wheels wobble, press brake gently and see if it changes. |
_________________ 1982 931
1986.5 Silver 928S
2008 Volvo XC90 (Daily)
Past lives (I miss them all):
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen) |
bureau13
Posted: Wed Mar 09, 2022 2:22 pm Post subject: |
Rear control arm bushings caused a vibration in the steering wheel?
To be honest, I'm sure mine are, let's just say not new Probably should be changed regardless...
| Fasteddie313 wrote: | Rear control arm bushings was the fix for me..
Could be all sorts of things, but those are pretty cheap and easy.. |
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
peterld
Joined: 10 Dec 2006 Posts: 983 Location: Noosa Heads QLD Australia
Posted: Thu Mar 10, 2022 12:11 am Post subject: |
Does your steering wheel move, or rather the steering column, when the car is at standstill? If so, it's the plastic bush at the top of the column. _________________ 80/81 932/8 ROW |
kondzi
Posted: Thu Mar 10, 2022 1:10 am Post subject: |
| peterld wrote: | | Does your steering wheel move, or rather the steering column, when the car is at standstill? If so, it's the plastic bush at the top of the column. |
+1
I was assuming driving wheel moves, because wheels wobble and the whole car shakes
So what's the case? _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
bureau13
Posted: Thu Mar 10, 2022 3:49 pm Post subject: |
The steering wheel shakes at speed. Actually, over a range of speeds, and when heavy braking, but say I speed up to 65, I will feel it, if I go faster it will get worse but sometimes I can get it into a sweet spot where it is hardly doing it at all.
I don't really feel anything obvious when I try to move the column at a standstill.
I had assumed that I was feeling vibration up through the wheels/tires/steering linkage, but all the obvious items there were dealt with, and it didn't improve. _________________ 1982 931
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
kondzi
Posted: Thu Mar 10, 2022 10:18 pm Post subject: |
Try to see if front wheels wobble. You can stick out your arm with phone in hand over the window and try to record it.
When doing this 65mph and your driving wheel shakes, press clutch pedal. Sometimes vibration from the drive shaft transfers to the rest of the car, but I doubt it.
When dealing with bent brake rotors with light braking it should shake, with hard shaking this should stop. If in your case as you state hard braking equals driving wheel shake / wheel wobble I think it's related to the front suspension.
How old are your tires?
Do you drive the car all the time or it was sitting not driven for a longer period? (tires could get deformed, flatten where touching ground - balancing will not help in that case)
Did you do a proper wheel alignment? Front and rear? _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Portporschedon
Posted: Fri Mar 11, 2022 2:04 am Post subject: |
[quote="bureau13"]Sorry, I wasn't clear...I feel it in the steering wheel. I don't know that wheels are actually doing anything, but my steering wheel shakes.
I understood your problem.
My problem was identical to everything you describe.
It took a wheel alignment check and a wheel balance to correct the problem.
Apparently Porsche will only do a 4 wheel alignment check (in the UK anyway), however any competent garage will be able to do a front wheel alignment and wheel balance.
My problem was sorted, yours may be caused by other issues, however a front wheel alignment & balance would be my first thing to check before I started pulling steering columns etc.
As has been mentioned, if the steering wheel can be moved side to side, its probably a bush or bearing in the column.
Good luck with the problem.
Regards
!tom
Posted: Wed Aug 31, 2022 5:39 am Post subject: |
Bent wheel _________________ 78 924 NA
5-lug |
Posted: Wed Aug 31, 2022 10:43 am Post subject: |
| bureau13 wrote: | Rear control arm bushings caused a vibration in the steering wheel?
The rear bushings on the front control arms.. _________________ 80 Turbo - Slightly Modified |
bureau13
Posted: Wed Aug 31, 2022 2:40 pm Post subject: |
That makes a lot more sense! I'll check them out. I would definitely prefer that to something in the steering linkage...
| Fasteddie313 wrote: | | bureau13 wrote: | Rear control arm bushings caused a vibration in the steering wheel?
The rear bushings on the front control arms.. |
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
Posted: Fri Sep 02, 2022 12:49 am Post subject: |
Mine looked and felt ok but replacing fixed the problem..
Was an easy job replacing with poly ones, sliced the old ones with a cutoff wheel and new slipped right on.. _________________ 80 Turbo - Slightly Modified |
bureau13
Posted: Mon Mar 20, 2023 2:46 pm Post subject: |
I put this issue on the back burner due to other priorities, but I removed my seized AC compressor today (finally!) and the steering shaft is right there. If I grab the shaft and shake it, there's not a lot of play, but enough to make this sound (see linked video). Is this normal? I'm guessing it's not, and could be the issue I'm feeling.
https://photos.app.goo.gl/cavL5oB9Vs675Xej9 _________________ 1982 931
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
james911996
Posted: Tue Mar 21, 2023 1:15 am Post subject: |
I had the same issue with a 944 Turbo a few years ago.
Wheels balanced, new tyres, new discs, etc. Lots of money spent with an independent transaxle specialist. To no avail.
Eventually went to a wheel shop. They took the two from wheels out and did 2 things:
- sanded them down where the wheel makes contact with the hub - they said there was some old paint not completely flat
- rebalanced the wheels (properly this time I guess)
And in 15mn it was all fixed.
So maybe try and find someone with modern wheel balancing equipment and try again.
Best of luck
James |
bureau13
Posted: Sat Mar 25, 2023 2:44 am Post subject: |
So no one knows if this "knocking" is normal? I guess unless the compressor is out of the way you don't really have access to it from the top.
| bureau13 wrote: | I put this issue on the back burner due to other priorities, but I removed my seized AC compressor today (finally!) and the steering shaft is right there. If I grab the shaft and shake it, there's not a lot of play, but enough to make this sound (see linked video). Is this normal? I'm guessing it's not, and could be the issue I'm feeling.
https://photos.app.goo.gl/cavL5oB9Vs675Xej9 |
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
