924 engine mods for increasing red line
daniel
PostPosted: Fri Mar 04, 2022 2:28 pm    Post subject: 924 engine mods for increasing red line Reply with quote
Hi All
I am in the process of rebuilding my race engine and have selected a cam that will result in peak power at ~ 7500rpm. I have already taken the following precautions:
- Pauter rods
- forged pistons
- lighter weight valves & appropriate springs.
I am concerned about the flywheel and lack of harmonic balancer on the front of the crank - has anyone had experience getting these engines to spin safely and reliably at this speed?
Cheers
1989 944 Cabriolet
PostPosted: Fri Mar 04, 2022 7:01 pm    Post subject: Re: 924 engine mods for increasing red line Reply with quote
daniel wrote:
Hi All
- Pauter rods
- forged pistons
Cheers
Do you have he lightweight lifter buckets aswell? Is the flywheel standard, lightened or custom?
What kind of intake and exhaust mani do you have? Are they tuned for high speeds?
924-76
PostPosted: Fri Mar 04, 2022 10:05 pm    Post subject: Re: 924 engine mods for increasing red line Reply with quote
daniel wrote:
Hi All
I am in the process of rebuilding my race engine and have selected a cam that will result in peak power at ~ 7500rpm...Cheers
As far as I know, the biggest restriction on 924 N/A for more power is the low air flow due to restrictive intake design (manifold and head). Please feel free to correct me if I'm wrong.
I'm curious to know why you went with such a high RPM cam?
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
PostPosted: Fri Mar 04, 2022 11:34 pm    Post subject: Reply with quote
I'd definitely be concerned about the lifters, if you haven't replaced the stock buckets. I've had them split right through the adjuster holes at 8000rpm.
I wouldn't be concerned about the lack of a harmonic balancer - just get the rotating assembly/bottom end balanced by a good shop.
daniel
PostPosted: Tue Mar 08, 2022 11:58 am    Post subject: Reply with quote
Hi Vaughn
Yes bottom end has been balanced - will get it checked again before reassembly. The cam buckets I have are new from a group buy. They are the ones that take the adjusting screw. I was going to ask the shop doing my head to machine down some of the boss that the screw sits in and use shims however if you have a better suggestion??
1989 944 Cabriolet
PostPosted: Tue Mar 08, 2022 10:18 pm    Post subject: Reply with quote
Seemed to me the weak point is the holes for the screws in the outer barrel; removing the screws won't fix that.
So I'd recommend finding a shim-based solution without holes in the sides...
MikeJinCO
PostPosted: Tue Mar 08, 2022 11:19 pm    Post subject: Reply with quote
The cam followers come from ACM in Sweden cost would be less than doing any machining, the last ones I got were about $120 per set. They weigh about 53gm vs 85gm+ so a significant weight reduction. This alone will decrease the load on the cam by 15-20%.
Hopefully you have a crank scraper or at least a baffle in the pan. The guy at crankscraper.com has a very sophisticated setupbut I had delivery problems with him several years ago. I made a flat baffle and welded it into the pan, a copy of early Mittlemotor. Someone in UK or Europe did a similar one that was curved to follow the crank closer. I can mail you a pattern if you like.
Mike
'67 MG Midget Dp
Mike9311
PostPosted: Wed Mar 09, 2022 12:15 am    Post subject: Reply with quote
Balance the flywheel dynamically on a pre-balanced custom shaft. Then bolt on clutch pressure plate and balance that with flywheel on same shaft. By having your motor balanced separately from the items you might change more frequently like the clutch, you are better off. This is also something Porsche worried about themselves. Its why there is a tuned damper in the torque tube. It wasn't so much new they were worried about but component swapping later like a new clutch not balance matched to engine.
Too bad you are so far away. I just did this and could do it for you
Edit: I also second everyone above with lighter valvetrain. The inertial response is improved tremendously every step you take to lighten. Lighter parts can change direction easier (better acceleration / + & - directions) which helps raise float ceiling i.e higher rpm capability. If the spring is kept the same, it will control things easier. It acts like stronger spring but with positive effects like less load on cam as MikeJinCo pointed out above. Basically win win other than setup. I also like that its less of a load on the contact line between the tappet and cam nose so the oil/additive package has a better chance of lubricating at that exact moment of peak force on that contact line.
1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
1982 931 wana-be GTR race car
