joemoma1990
Joined: 29 Jun 2021 Posts: 32 Location: Apple Valley, MN
Posted: Thu Jan 20, 2022 12:43 am Post subject: WUR testing |
I finally got it started but it is running rough and I have to tap the flap to add fuel to get it to smooth out. So I assumed there is a problem with the WUR. I want to make sure I am testing this correctly.
I hooked up my gauge to the center hump on the fuel distributor.
I tested the pressure with the valve closed. I am getting 80 psi.
I open the valve up and the pressure dropped but immediately went to 80 psi
So I assume the WUR is bad? I had it out this last summer and cleaned and I think tested it correctly, if I tested this correctly I want to replace it. It's -5 here in Minnesota not going to get to pulling it out quickly is there multiple part numbers for it? I was going to order 0 438 140 011 from Special T
TIA |
Joined: 29 Jul 2001 Posts: 9073 Location: Royal Oak, MI, USA
Posted: Thu Jan 20, 2022 1:54 am Post subject: |
Yup, that's a bad WUR - it should stop at a lower control value, per the manual, once the valve is opened.
There are multiple part numbers, unfortunately. _________________ Vaughan Scott
Eliza
Joined: 17 Aug 2015 Posts: 174 Location: Prov. Utrecht, The Netherlands
Posted: Fri Jan 21, 2022 4:07 pm Post subject: |
Depending on model year and engine, PET does show which WUR should be the correct one. The Bosch number you have is for an n/a ( at least for RoW cars ) not a turbo.
Time to go cross-referencing
Eliza _________________ 1985 924 NA RoW
1981 931 S2 RoW |
