brand new stainless 931 turbo manifold !!
anthonimartini
PostPosted: Sat Jan 08, 2022 2:42 pm    Post subject: brand new stainless 931 turbo manifold !! Reply with quote
not sure if anybody here has seen this but it looks neat!
https://www.fiammenghiitalia.com/en/prodotto/stainless-steel-exhaust-manifold/
ive saved alot of 924's
current:
79 MochaSchwartz 931
83 944
87 924S
formerly known as turbellion, lost password.
PostPosted: Sat Jan 08, 2022 3:46 pm    Post subject: Reply with quote
Wow!
80 Turbo - Slightly Modified
PostPosted: Sat Jan 08, 2022 7:40 pm    Post subject: Reply with quote
I was pretty excited until i saw the final product. A cast steel copy of the Rhd 931 manifold would be nice to have
Mike9311
PostPosted: Sun Jan 09, 2022 3:17 am    Post subject: Reply with quote
I guess I am not the only one scanning these things
1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
1982 931 wana-be GTR race car
gegge
PostPosted: Tue Jan 11, 2022 10:00 pm    Post subject: Reply with quote
A simple log is far from "optimized design"
That is inferiour to the cast OEM manifold I am afraid.
Carl Fredrik Torkildsen
PostPosted: Tue Jan 11, 2022 11:30 pm    Post subject: Reply with quote
the standard manifold surely has a better design for a log manfiold with smoother bends. However according to my GT power calculations the RHD manifold have better cylinder balance when the WG opens, and would be better for knock mitigation on cylinder 4.
Beartooth
PostPosted: Thu Oct 13, 2022 7:46 am    Post subject: Reply with quote
I've been paging through Corky Bell's book on turbocharging, and in the section on exhaust manifolds/headers, he states that a simple log manifold with the turbo on one end and the wastegate on the other is sub-optimal. I'm not sure if there's an issue with efficiency, if it might feed the turbine with enough exhaust to overboost even with the wastegate open, or what, but I was a little disappointed when I saw what I thought was that type of standard log manifold on my 931. After I got it off, I realized it's not like that; there's a separate passage running most of the length of the manifold from near the turbo flange back to the wastegate outlet. Again, I don't fully understand if it's a necessary element, necessary only in some cases, or just nice to have, but it was important enough for Porsche to put in the effort to incorporate.
Anyway, I know this is from a few months back, and I applaud the effort somebody put in, but I'd only consider the manifold in question if I couldn't get my hands on an original cast manifold. And if I were to run it, I'd do a number of controlled test runs looking for erratic operation before I'd trust it. What would be really cool to see would be a four-into-one or 2-2-1 tube manifold, probably with the wastegate pipe picking up just behind the turbine flange and looping over the top back to the original wastegate connection. But that could be a fabrication and packaging nightmare...
1980 931 diamond in the rough
