mungodrums
Posted: Sun Nov 21, 2021 12:25 pm Post subject: Does Xylene work to help pass smog? |
| I want to make sure the second time around that my 88 924s passes smog. Should I put in gallon of xylene along with 91 octane gas? How much gas should i put in along with 1 gallon of xylene? Im in Ca. Thx. |
MikeDanger
Posted: Mon Nov 22, 2021 1:13 pm Post subject: |
no it wont, run as much pure alcohol as you can. _________________ It was either this or a giant box of legos |
mungodrums
Posted: Mon Nov 22, 2021 2:44 pm Post subject: Where do I find pure alcohol? |
| Where do I find pure alcohol? 99% alcohol, 100%? How much should I put in tank and also how much 91 octane gas? Ger. |
safe
Posted: Mon Nov 22, 2021 7:57 pm Post subject: Re: Where do I find pure alcohol? |
| mungodrums wrote: | | Where do I find pure alcohol? 99% alcohol, 100%? How much should I put in tank and also how much 91 octane gas? Ger. |
E85 will work depending on what you are failing on, it will make the car run leaner and lower Co. _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe |
