Front spring diameter?
Riggard
PostPosted: Thu Oct 21, 2021 5:07 am    Post subject: Front spring diameter? Reply with quote
Hi, I got a '81 924, and a lot of spare parts with it. It came with from springs 12mm in diameter, but I also got some spares that are 12,5mm in diameter.
Can anyone explain me the difference? e.g. were the thicker ones used in a newer model year? or maybe another model?
Thanks!
PostPosted: Fri Oct 22, 2021 6:12 am    Post subject: Reply with quote
You didn't say if they were factory springs or aftermarket. The 12.5 mm springs have a higher spring rate than the 12 mm ones. Are they the same height?
Riggard
PostPosted: Fri Oct 22, 2021 6:40 am    Post subject: Reply with quote
Same height, not sure if they're factory or not, appear to be factory, but can't tell for 100%
PostPosted: Fri Oct 22, 2021 8:03 am    Post subject: Reply with quote
It's probably not worth the effort to replace the existing front 12 mm springs with the others. Did you get any sway bars with the car? Those will change the handling more that just swapping front springs.
Riggard
PostPosted: Sat Oct 23, 2021 3:49 am    Post subject: Reply with quote
I'm replacing the dampers, so its 0 effort to replace the springs.
Just a bit concerned that it may raise the front (same height, stronger springs = less sag)
PostPosted: Sat Oct 23, 2021 10:11 am    Post subject: Reply with quote
True that.
gegge
PostPosted: Sun Oct 24, 2021 12:28 am    Post subject: Reply with quote
Stock springs were black with 1, 2 or 3 green or blue markings. The CGT springs are shorter and stiffer and got red marknings. M030 got red as well. Belive first year got them too.
Carl Fredrik Torkildsen
