lildude4life
Posted: Wed Sep 29, 2021 11:13 pm Post subject: |
| Cedric wrote: | | Nice with some results! Could you possibly get a graph that has less brutal smoothening factor, it would be great to see how it really looks like. How does the boost curve looks like? |
Yes lol. Pretty sure he took a screenshot with his phone and texted it to me. Ill get a nice printout when I get the car later this week.
I know he said max boost doesn't hit unitil like 4500ish? Last chart he gave me had all 3 tracks on it so I would expect I can get the same. _________________ "931 EFR" 81 931 S2 w/ EFR 6258 turbo, EFI, Haltech Elite ECU, 240whp |
chuck21401
Joined: 20 Feb 2005 Posts: 611 Location: Annapolis, MD
Posted: Fri Oct 01, 2021 9:22 am Post subject: |
| lildude4life wrote: | | 261whp/ 245lbft super happy. EDIT. these numbers were with 109oct. He was hoping he could hold the timing and boost levels when he went back to 93 as he knew he could go further than 16.5 with 109,,, but he could not.... likely going to be in the 14.5psi, 240whp/220lbft range. |
Wow. That's great.
Maybe I missed it....did you also upgrade the heat exchanger up front? _________________ 1981 Porsche 931 w/S1 engine & euro g31 transaxle. Water-cooled intercooler |
Mike9311
Posted: Fri Oct 01, 2021 11:28 pm Post subject: |
He did but I can't find the link for you...I'll dig around if he doesn't reply _________________ 1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
lildude4life
Posted: Sat Oct 02, 2021 12:51 am Post subject: |
| chuck21401 wrote: |
Wow. That's great.
Maybe I missed it....did you also upgrade the heat exchanger up front? |
Yes. Went just a little bigger... I can post more photo's next week of it installed if interested. Out of town this weekend, picking the car up Monday.
chuck21401
Posted: Sat Oct 02, 2021 2:46 am Post subject: |
Great. Will be interested to see how you mounted it. I mounted a larger one as well and it seems to bean improvement but I really need a better set up to measure intake air temperatures.
I ran into a small problem with air in the system...took a while to figure that out. I was using h20 only so wasn't a big deal when bleeding the system and spilling water everywhere. As the temps go down I'll need to switch back to antifreeze 50/50.
I've also noticed that the radiator fan does a nice job pulling the air through the heat exchanger at idle. So that helps too. _________________ 1981 Porsche 931 w/S1 engine & euro g31 transaxle. Water-cooled intercooler |
lildude4life
Posted: Tue Oct 05, 2021 12:03 pm Post subject: |
| chuck21401 wrote: |
Here you go! Get a GM fast responce sensor and put it in the stock air temp location. It seems the best.. Not sure if it works with your setup. I just had to add about 5oz of water to the IC loop.. Still pumped fine but was clearly way low. I did make a container that you can put in line at the top of the IC to help fill it. I'll take a video if I use it.
Yes lots of elbows......
I did have to drill 2 holes for the M8 studs to go through.
Mike9311
Posted: Wed Oct 06, 2021 11:24 pm Post subject: |
On the '82 I added a bleeder by drilling a hole in the 90 deg elbow at the back of the intercooler, it being the highest point. Threaded for a small NPT plug. Inspired by the bleeder at the thermostat housing. used a tiny funnel to fill after that
Just kept opening that up to bleed over the period of a few drives.
Probably could come up with a system to power fill from below but too much trouble.
The CS has a fill cap inline with the hose up top _________________ 1980 931 since 1989
Juho
Posted: Thu Apr 07, 2022 3:04 am Post subject: |
| Do u have picture how and where u mounted knock sensor, ive never tuned a car and decided to go with wasted spark so a knock sensor would be nice |
Posted: Thu Apr 07, 2022 3:10 am Post subject: |
| Juho wrote: | | Do u have picture how and where u mounted knock sensor, ive never tuned a car and decided to go with wasted spark so a knock sensor would be nice |
Check under the intake on the block, there's a very good hole that you can use there. What does wasted spark has to do with knock? _________________ 1980 924 Turbo
Juho
Posted: Thu Apr 07, 2022 3:14 am Post subject: |
| Cedric wrote: | | Juho wrote: | | Do u have picture how and where u mounted knock sensor, ive never tuned a car and decided to go with wasted spark so a knock sensor would be nice |
Check under the intake on the block, there's a very good hole that you can use there. What does wasted spark has to do with knock? |
I just mean ive never tuned a car and im converting into a wasted spark system and probaly will tune ignition to a some point. I have friend who has tuned itbs before but i would like a knock sensor |
Posted: Thu Apr 07, 2022 3:22 am Post subject: |
| Juho wrote: | | Cedric wrote: | | Juho wrote: | | Do u have picture how and where u mounted knock sensor, ive never tuned a car and decided to go with wasted spark so a knock sensor would be nice |
Ok i get it, its of course less sensitive on an n/a engine. But it could be a good idea to learn how to tune and setup knock detection on an engine like yours that won't grenade itself easily. What system are you planning to use? _________________ 1980 924 Turbo
lildude4life
Posted: Thu Apr 07, 2022 8:42 am Post subject: |
Ask and you shall receive! Kinda hard to take a photo of, but I think you should be able understand it.
chuck21401
Posted: Wed Oct 26, 2022 2:51 am Post subject: |
How did the larger heat exchanger work out?
I'm thinking about going bigger. My car no longer has A/C so I think there is plenty of room.
This one is 20" X 8" X 2:
https://www.edelbrock.com/dual-pass-single-row-universal-heat-exchanger-20-w-8-h-2-d-20-500-btu-15549.html
mattmax1981
Joined: 15 Mar 2020 Posts: 6 Location: Memphis, TN, USA
Posted: Sat Oct 28, 2023 7:52 am Post subject: |
Very cool build!
What type of alternator are you running? Did you have to do much fab work to mount it? |
lildude4life
Posted: Sat Dec 02, 2023 2:48 pm Post subject: |
| mattmax1981 wrote: | Very cool build!
Howdy. I have the one Dan use to sell. I don't know exact model but I imagine someone on here does. No modifications needed other than a smaller belt. Stock lenth was too loose.
https://web.archive.org/web/20190422165911/https://garage.ideola.com/prod-ElectricsUpgrades.html#OEM
| chuck21401 wrote: |
I'm thinking about going bigger. My car no longer has A/C so I think there is plenty of room. |
Sorry for the year late reply, but I did want to run it again for another summer before I could truly answer. I think pretty well. I haven't done a ton of data logging but have never had knock issues on normal boost even in sweltering conditions. Still get the knock warning when I go in to "go baby go mode" and it slams up to 16psi in 2nd and 3rd. I don't think any amount of cooling will help with that. Probably going to dial the target back a bit so I can still have a low/high but without knock light tripping. _________________ "931 EFR" 81 931 S2 w/ EFR 6258 turbo, EFI, Haltech Elite ECU, 240whp |
