A/C Mounting bushings
mattaebersold
PostPosted: Tue Aug 10, 2021 8:11 am    Post subject: A/C Mounting bushings Reply with quote
931 A/C compressor seems bent inwards towards the firewall (I can upload a photo is that's helpful). And looking at it, it seems like part of the cause is the rubber bushings that mount the compressor to the bracket seem very worn out.
I'm worried that the AC belt will have too much wear since it will be pulled at an angle.
Some options that I'm considering:
1. remove the AC compressor. I don't mind not having A/C. I don't want to get under the dash to FULLY remove it, but at least the comressor and accessible lines in the engine bay. If that ends up happening, I can just run the main serpentine belt from the oil pump -> alternator -> water pump by themselves right? Like it's a separate belt on the 2.0 to connect the oil pump and the A/C unit right?
2. find new bushings
Looking online, I don't see anything other than used brackets with stock rubber bushings. Anyone know of a source for just the mounting bushings that get pressed into the bracket?
PARTSTASH: www.partstash.com
1980 931
1991 Japanese Classic Mini
2000 740i
2006 530xi Wagon
mattaebersold
PostPosted: Wed Aug 11, 2021 1:43 am    Post subject: Reply with quote
1980 931
2000 740i
2006 530xi Wagon
Goldwolf
PostPosted: Sun Aug 29, 2021 11:46 pm    Post subject: Reply with quote
I bought these bushings from Automotive Atlanta, pricey but cheaper than having them fabbed up. Einmalig may have them too.
1981 Weissach Edition #179
