944 Intercooler Install Question
dwak
PostPosted: Mon Dec 02, 2002 6:34 am    Post subject: 944 Intercooler Install Question Reply with quote
I'm just about to install the 944 intercooler but all the photos I've seen show the rad support/fender brace cut all to hell.
Doesn't this greatly weaken the car structurally and what additional bracing are like minded people out there doing?
dwak
81turbo
PostPosted: Mon Dec 02, 2002 11:39 am    Post subject: Reply with quote
You could always have that section cut out of a 951 and weld in the place of yours. Otherwise my best advice is don't hit anything with the front of your car.
Fast924Turbo
PostPosted: Mon Dec 02, 2002 11:54 am    Post subject: Reply with quote
Hi Dwak,
Here's the stock 944 cooler built for the 944 Turbo engine bay. And it's the same chassis as ours. Below it are two modified 944 coolers:
The stock cooler is top, Stage 1, middle, and Stage 2, bottom. So they've improved the 944 cooler with 18% better flow by just adjusting the end caps with Stage 1. Stage 2 is still the same core, but with modified end caps. Now imagine if you can do even better, and I think you can, with slightly different end caps that better fit the 931 Turbo outlet hose placement. Remember, our turbo is placed WAY differently than the 944 turbo, so why keep the same angles?
Consider that in the picture above, there is an acute angle. However, in OUR cars, I don't think we NEED so acute an angle. I think you're asking absolutely the right question, but before you build it the way others have built it, let me plant a seed in your head for a second.
Is the 944 Turbo cooler the best placement and setup?
Here's just a side note for you to mull over and maybe consider BEFORE cutting to suit a STOCK cooler: Consider getting different end caps for the cooler and have them welded on BEFORE the cutting begins. All the 944 turbo AFTERMARKET enhancements for the intercooler, where they've IMPROVED the 944 cooler, have different end caps for better flow - but it's the same core! So I might as well plant that thought in your head now before you go ahead and cut anything.
Can you lessen the acuteness of any angle by 10 degrees? 20 degrees?
Apparently, each 90 degree angle is equivalent to adding literally YARDS of piping. If you can cut and create the cooler placement (with the right end caps) so you may be able to AVOID these right angles, your flow increases incredibly.
Here's something else to think about too:
http://www.designengineering.com/cryo2_related_items.html
BTW: I know the 'standard' tactic is to plop in the 944 Turbo intercooler . But even the 944 boys are figuring out ways to do better than Porsche for intercooler design and placement.
dwak
PostPosted: Tue Dec 03, 2002 12:19 am    Post subject: Reply with quote
I think what impresses me about the 944 cooler is it's heat sink qualities which seems to be a big plus at low speed and idling.
Rick, take a look at my question below, didn't you replace that part? Aus Pete's used intercooler article made me re-think about my Supra light weight cooler.
dwak
PostPosted: Tue Dec 03, 2002 1:41 am    Post subject: Reply with quote
I don't think the upper rad area is that much of a structural piece, really. I'm not too concerned about cutting it up, though I still have no idea when I'll get around to installing one. The car is still very uncooperative about getting running.
Eturbo924
PostPosted: Tue Jan 28, 2003 1:42 am    Post subject: Ideas Reply with quote
Check this site out. Says it has a radiator and intercooler that bolts right in to 931. No chassis cuting.
"Intercooler - The intercooler is simpler than a charge cooler in that it is merely an air-to-air radiator situated between the turbo and the throttle body, usually located in the front of the car to maximise the cooling airflow. Unfortunately the 931 has no space to get the pipework past the standard radiator, so our system includes a replacement high-output aluminium radiator and intercooler to fit into the existing bodywork without modification. Available exclusively from 930 Motorsport.."Tuning Guide for the 924 Turbo (931)
930 Motorsport, Unit 23, Bank Quay Trading Estate, Warrington, WA1 1PJ
Tel 07000 930930 or +44 (0)1925 242342
Fax +44(0)1925 417638
Email: cdb930930@aol.com
www.930motorsport.co.uk
See some ideas here. http://www.cd-sales.co.uk/html/tuning931.htm
1992 968
2003 C4S
E-mail me for parts you need!
Drive Fast!
PostPosted: Tue Jan 28, 2003 1:55 am    Post subject: Reply with quote
Monster Garage rocks.
juno
PostPosted: Wed Jun 09, 2004 2:05 am    Post subject: Re: Ideas Reply with quote
I found that page too by googling around, but after calling them, the guy told me they haven't made any for years. They could still get one made up, but it would be getting on for £3000 each. BTW, they were about £700 5 years ago.
1980 924 Turbo RHD. 3" > 2.5" Stainless straight-through exhaust.
PostPosted: Wed Jun 09, 2004 3:00 pm    Post subject: Reply with quote
I would recommend getting the rad support out of a 951, and also the front piece between the 2 frame rails, and the weld it into yours, that would be the proper way to do it, however with the 931, the where the alt is positioned and the fuel dizzy to make the front mount air air IC effective you would have to convert to EFI to loose the fuel dizzy and gain room there, just to go slightly off topic here, on this page http://www.924.org/projects/projectLJ.htm there is a pic 2/3 of the way down showing this brace, and in order to answer the question on the page which is "why this brace/piece/tube is on the 931's frame?" the answer is, the fuel dizzy sits right above it and in the event of a MAJOR front end collision this tube bents up pushing the fuel dizzy into the hood and ABOVE the engine, w/o this tube here the fuel dizzy gets pushed straight into a possible red hot exhaust manifold. but back onto the post, and the Alt would have to be moved down to the location of where the AC compressor (for those of you that still have it) is. and then there would be enough room for the tubing, I would also think that in this instance you may consider creating a seperate oil supply for the turbo to keep the stuff the engine produces out of the turbo (this will increase the turbos life) with an electric pump to circulate the oil, and you also should be able to find another K26 gen turbo with a different intake compression housing with angles better suited to the IC install. however you may have to install an aftermarket BOV/POV in a different location as you would probably loose it with the change of compressor housing.
3 928s,
u000533
PostPosted: Thu Jun 10, 2004 6:33 pm    Post subject: Reply with quote
Hi, check out this site for some great shots of a 944T with the intercooler out, http://www.cannell.co.uk/944%20Turbo%20-%2018.htm.
I've had to replace the panel behind the badge panel on my 924T and I'd say that the strength is in the chassis rails as thats what the bumper is attached to. On the 944T the sloping panel behind the badge panel is removed to allow space for the intercooler and there are larger holes in the bonnet support bracket to allow for the pipe runs.
The photos on the 944 site show it in detail, the black panel you can see in the intercooler space is a scoop to draw air into the cooler, which you wouldnt need if you have a 924 4 slot badge panel.
regards
Mike.
1981 931 turbo - sadly sold
juno
PostPosted: Thu Jun 10, 2004 10:34 pm    Post subject: Reply with quote
Here's a company that sells the modified intercoolers above. Their stage 1 is £249 plus a 951 core though.
bigredtruck69
PostPosted: Fri Dec 14, 2007 5:09 pm    Post subject: intercooler Reply with quote
Ill get you some pics of mine fitted in my car but i cant remeber what we cut to be honest
vexed73
PostPosted: Fri Dec 14, 2007 10:23 pm    Post subject: Re: intercooler Reply with quote
wheres the company?
1982 PORSCHE 931
