anthonimartini
Joined: 17 Feb 2020 Posts: 240 Location: portland oregon
Posted: Sun Jun 20, 2021 2:04 am Post subject: wristpin bushing resize to 22mm |
so my dprod style engine is pretty much ready to assemble but im having a hell of a time finding a machine shop to rebush my stock rods to 22mm to use the vw flat tops. does anybody know of a shop that can do it? _________________ ive saved alot of 924's
current:
79 MochaSchwartz 931
83 944
87 924S
formerly known as turbellion, lost password. |
Posted: Sun Jun 20, 2021 9:17 am Post subject: |
Call EBS Racing in Reno, they can get bushings(I think Crower) to resize the 24mm to 22mm. _________________ Mike
anthonimartini
Posted: Sun Jun 20, 2021 11:36 am Post subject: |
thanks! im gonna try and contact crower directly. _________________ ive saved alot of 924's
current:
83 944
87 924S
Mike9311
Posted: Mon Jun 21, 2021 11:43 am Post subject: |
Let me know how this goes. There are shops out there that do this since I have researched this a bit over a half a year ago
Recently I was building a turbo motor where I was going to offset bush the rods so my piston CH (Compression Height) distance could be adjusted. Opened up piston choices for me. I know think my rods might be better suited for a NA build and not heavy boost shock. Will likely move back to Crower's
I can't recall the valve clearance with the flat tops but you may have room to play around with offset bushings as well. _________________ 1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
Euro924S2
Posted: Fri Jul 02, 2021 4:32 am Post subject: |
Would be good to know if a place to buy bushings. I’ve asked my engine machine shop to make them for my 16v build when I dropped off the block, crank, rods and pistons yesterday. I didn’t tell them they were only 1mm wall thickness but they said, yeah, we make small end bushes from time to time, no problem! Hopefully they don’t retract on that statement!! _________________ UK spec '83 N/A with 931 motor with Eaton MP62 'charger @ 15psi. EFI - 565cc inj. Standalone Adaptronic ECU. 951 FMIC. Ally rad. Twin throttle. Recirc valve. Custom manifolds and CAI. 232bhp |
gegge
Posted: Sat Jul 03, 2021 5:56 pm Post subject: |
I ordered 22mm bushings from Peter Nowen Motorsport 5 years ago: https://www.facebook.com/NowenMotorsport/
They were parts made for Saab OD 27,05mm ID 22,00mm and width 25,5mm _________________ Carl Fredrik Torkildsen
Euro924S2
Posted: Fri Jul 16, 2021 6:55 pm Post subject: |
Plenty of VW type 4 piston small end bushings listed on google which are 24mm OD and 22.4mm ID. These bushings are designed to be pressed in to the rod, then reamed to final size once fitted so could be reamed to 22mm for the flat top pistons I imagine. Then have the oil hole drilled?
Example seller:
https://www.coolairvw.co.uk/product/021105431aks/ _________________ UK spec '83 N/A with 931 motor with Eaton MP62 'charger @ 15psi. EFI - 565cc inj. Standalone Adaptronic ECU. 951 FMIC. Ally rad. Twin throttle. Recirc valve. Custom manifolds and CAI. 232bhp |
Posted: Thu Sep 09, 2021 3:55 am Post subject: |
Just received 22mm reducing bushings from EBS Racing, were in stock and $10 ea. 27mm OD, 22 Id undersized sized for ream to size. My motor machinist did not want to go about ordering pistons without the bushings in hand. _________________ Mike
Euro924S2
Posted: Thu Sep 09, 2021 4:26 am Post subject: |
Good info! 27mm? I thought 924 were 24mm - apologies if ive got that wrong, makes my post above completely irrelevant!
My block and pistons are with the machinist now and should be ready in 2 weeks - he’s machining some bushes for me though, but I doubt he’ll churn them out for £10, let alone 10USD! I’d pay 3x that in shipping and tax though! _________________ UK spec '83 N/A with 931 motor with Eaton MP62 'charger @ 15psi. EFI - 565cc inj. Standalone Adaptronic ECU. 951 FMIC. Ally rad. Twin throttle. Recirc valve. Custom manifolds and CAI. 232bhp |
Mike9311
Posted: Fri Sep 10, 2021 10:56 pm Post subject: |
| Euro924S2 wrote: | Good info! 27mm? I thought 924 were 24mm - apologies if ive got that wrong, makes my post above completely irrelevant!
My block and pistons are with the machinist now and should be ready in 2 weeks - he’s machining some bushes for me though, but I doubt he’ll churn them out for £10, let alone 10USD! I’d pay 3x that in shipping and tax though! |
I think you misunderstood. The pin is indeed 24 but the new bushing is 27x22 for a 22mm wrist pin. so stock is 27x24 _________________ 1980 931 since 1989
Euro924S2
Posted: Sat Sep 11, 2021 6:09 pm Post subject: |
Ah, yes, my bad! Makes much more sense to install one new thicker bushing, than insert a bush within a bush!
Got me wondering now what my shop is planning/doing! _________________ UK spec '83 N/A with 931 motor with Eaton MP62 'charger @ 15psi. EFI - 565cc inj. Standalone Adaptronic ECU. 951 FMIC. Ally rad. Twin throttle. Recirc valve. Custom manifolds and CAI. 232bhp |
