Joined: 28 Feb 2008 Posts: 1423 Location: Washington DC area
Posted: Tue May 04, 2021 5:05 am Post subject: Alternator bushings |
My race car alternator bushings were new when I built the car several years ago. Now they are mush and the alternator is kind of cocked. Does anyone have any suggestions as to where to get replacements or should I go with making brass ones? _________________ 1979 924 NA race car H-Prod SCCA
Riggard
Joined: 16 Feb 2021 Posts: 90 Location: Heemskerk, Netherlands
Posted: Tue May 04, 2021 6:41 am Post subject: |
The first guy I went to made some aluminum ones as was in a hurry, they wore out quickly. Then went to steel and they are good, now the solid mounting is like the rest of the world uses. _________________ Mike
Posted: Tue May 04, 2021 9:01 am Post subject: |
Mike, thanks. I was rooting around below my lathe looking for old brass stock but couldn't find anything. I'll give it a go with steel. _________________ 1979 924 NA race car H-Prod SCCA
Posted: Tue May 04, 2021 9:11 pm Post subject: |
Chuck, If you are making some I'd happy take another set. To me these rubber bushings are not one of Porsche's better ideas. I will grant that being solid will put a little more stress on the alternator and water pump bearings. _________________ Mike
Posted: Wed May 05, 2021 6:30 am Post subject: |
I couldn't find any ready made tubing M8 ID, 19 MM OD so I had to order some 19 MM rod. It seems the minimum length is 7 FEET. I need an inch and a half per alternator.  _________________ 1979 924 NA race car H-Prod SCCA
jacobroufa
Joined: 18 Nov 2016 Posts: 531 Location: Belvidere, IL
Posted: Thu May 06, 2021 11:28 pm Post subject: |
If you've found yourself with that dilemma of too much material, I'd happily pay for a set of solid alternator bushings for both my 924 and 931. I replaced the 924 with stock rubber a few years back but doubtless they'll wear out again in a couple years, and my 931 bushings work but are pretty worn, and impossible to find.. _________________ 1980 Porsche 931
1981 Porsche 924 Weissach |
Posted: Fri May 07, 2021 2:21 am Post subject: |
What are they OEM on a 931?
Iirc my alt mounts where it hinges are brass.. _________________ 80 Turbo - Slightly Modified |
GregSC
Posted: Fri May 07, 2021 4:57 am Post subject: |
I'd be happy to pay for a set of 931 bushings as well. Been looking for a good replacement for the original bushings for a while. _________________ 1981 931 |
Posted: Fri May 07, 2021 6:42 am Post subject: |
Jacob,
Can you take pictures of the 931 and 924 bushings? If they are the same, I can make some. My only 931 engine is buried in a storage bin and I know that the alternators are located on the opposite sides of the engine. It may be a different mount/bushing????
Eddie, sounds like someone already made an improvement on your engine. _________________ 1979 924 NA race car H-Prod SCCA
