No spark 87 924s
BurialWings
PostPosted: Fri Apr 16, 2021 11:03 am    Post subject: No spark 87 924s Reply with quote
So I am having a no spark issue. Coil tests good, dme relay tests good, dme relay jump made no change. Brand new ref sensor properly gapped, tach is bouncing. Down to thinking it could possibly be the SCR pulse trigger in the DME, though upon inspection it looks great. Any ideas or tests I could try out would be greatly appreciated.
PostPosted: Fri Apr 16, 2021 11:23 am    Post subject: Reply with quote
How did you verify it isn't sparking? When did the car last run?
BurialWings
PostPosted: Fri Apr 16, 2021 11:31 am    Post subject: Reply with quote
Tested spark with test light, spark plugs, and a screw driver from the main line. It's been sitting awhile. I bought it non running with smashed pistons and valves and did a rebuild, so I have never had it run but was obviously running to cause catastrophe for the previous owner.
PostPosted: Fri Apr 16, 2021 12:11 pm    Post subject: Reply with quote
Sounds like you verified the coil isn't firing.
Fastest test involves a known good DME. If you're committed to the car, the Focus9 solid state DME is a great investment.
safe
PostPosted: Fri Apr 16, 2021 8:23 pm    Post subject: Reply with quote
Jump the DME relay for a start, pin 30 to 87 and 87b.
If that doesn't work I would check/replace the crank sensors.
Edit: Also check that the relay socket connectors have a good connection , sometimes they can be a little loose so the connection is poor.
Not sure if the 924s has any of the old cheramic fuses, those can be prone to corosion and moving them a little might sometime solve issues. Same with modern blade fuses, just not so much.
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
BurialWings
PostPosted: Fri Apr 16, 2021 10:39 pm    Post subject: Reply with quote
Crank sensors are new and gapped. I jumped the relay and tested it with a multimeter, it reads as functional on the multimeter, but jumping it made no change.
I'm going to pull the fuse boxes later today and check on connections, it is the old style ceramic ones.
Ordered a new dme relay just to check but will be a few days, though that doesn't seem to be the issue as jumping it didn't do anything.
PostPosted: Sat Apr 17, 2021 12:33 am    Post subject: Reply with quote
When I suggested testing with a known good DME above, in case it wasn't clear, I was referring to the computer itself.
PostPosted: Tue Apr 20, 2021 6:57 am    Post subject: Reply with quote
Make sure the rotor is not loose on the distributor shaft.
BurialWings
PostPosted: Tue Apr 20, 2021 7:17 am    Post subject: Reply with quote
So fiddling around today, when a new dme relay came in, it seems that plugging it in forces the socket of 87b out the back rather than connecting to the relay. So trying to get it to hold position without much wiggle room for my fingers on the wire. Hopefully it solves the issue.
PostPosted: Tue Apr 20, 2021 7:19 am    Post subject: Reply with quote
I'd lower the relay panel and fix that wire. Disconnect negative sure of battery first.
