alternative conrod choices
Goto page Previous  1, 2, 3, 4  Next
anthonimartini
PostPosted: Mon Mar 29, 2021 1:11 pm    Post subject: Reply with quote
you would probably have enough tilt on the rod a bit past bdc to get your 11mm socket on them. but you do raise a good point that i didnt think of. on the aircooled engines i assemble the entire crank with rods in a stand and plop it down on the case half. im not entirely sure these rods will cut it anyways. im getting some sizing descrepencies on the big end bore. the 914 crank journals are 50mm std and ours are 48mm so im not sure a undersize bearing will work. i need to see what i can get bearing wise. i may be offset grinding my crank to use this rod but with a chevy journal. its getting muddied. i may end up just spending half a day lightening and balancing my stock rods. i just dont want to spend 250 bucks on rod bolts just to keep the stock stuff.
ive saved alot of 924's
current:
79 MochaSchwartz 931
83 944
87 924S
formerly known as turbellion, lost password.
Juho
PostPosted: Mon Mar 29, 2021 1:16 pm    Post subject: Reply with quote
what is wrong with the bmw rods, why dont make them work?
anthonimartini
PostPosted: Mon Mar 29, 2021 1:51 pm    Post subject: Reply with quote
the only problem with them is how narrow they are. im honestly not sure if its really a problem. i have read stuff arguing both sides. im considering getting my crank journals welded and machined narrower as to keep the rod to crank tolerance within spec. i need to talk to a my machinist about this first. hes built tons of race engines and id like to get his perspective on it. as a side note many of the aircooled motors i built were extremely loose there as well. but the bmw rods are over .100" gap.
current:
83 944
87 924S
Juho
PostPosted: Mon Mar 29, 2021 2:10 pm    Post subject: Reply with quote
is welding the crankjournals and machining them expensive?
anthonimartini
PostPosted: Mon Mar 29, 2021 2:17 pm    Post subject: Reply with quote
im not entirely sure yet.... probably. im hoping he tells me with confidence not to worry about the looser gap but i suspect that will not be the case. i also could consider using the nascar method of controlling the rod axial movement with spacers at the wrist pin but to do that properly is also kinda tricky and will involve getting rid any taper on the piston. i just wish those chinese companys would make us some rods!
current:
83 944
87 924S
Juho
PostPosted: Mon Mar 29, 2021 2:32 pm    Post subject: Reply with quote
gegge used washers sucessfully
anthonimartini
PostPosted: Mon Mar 29, 2021 2:59 pm    Post subject: Reply with quote
ill have to ask him how he did it. he used vw flat tops correct?
current:
83 944
87 924S
Juho
PostPosted: Mon Mar 29, 2021 3:45 pm    Post subject: Reply with quote
"No, I dont have any pictures of the washers. They were made of aluminium with a very tight 22mm clearence. Cant remember thickness or outer diameter." this is what he said to me
Juho
PostPosted: Mon Mar 29, 2021 3:46 pm    Post subject: Reply with quote
Another connecting rod choice
https://www.maxpeedingrods.com/product/mitsubishi-eclipse-1g-2.0l-4g63-150mm-connecting-rod-high-performance-4340-en24-h-beam-conrod.html
Grind journals to 48mm and widen them 0.4mm
Cant run flat tops with these rods though
Juho
PostPosted: Mon Mar 29, 2021 4:46 pm    Post subject: Reply with quote
https://www.alibaba.com/product-detail/Forged-4340-Steel-Conrod-For-MERCEDES_62119680142.html
Im pissed, these rods would be perfect but min orded would be 20pcs and each would be 42 dollars
No idea about quality but i think they would be ideal if you didnt want to grind crank.......[/url]
Juho
PostPosted: Mon Mar 29, 2021 5:11 pm    Post subject: Reply with quote
Ok ive dug too deep , these are min order only 6pcs
https://www.alibaba.com/product-detail/billet-crankshaft-piston-m103-m104-H_60796882625.html?spm=a2700.12243863.0.0.72833e5fUyfCMO
Dimensions 145mm-51.6mm-22, width 22 mm
motormouth
PostPosted: Tue Mar 30, 2021 1:12 am    Post subject: Reply with quote
Mitsubishi rods from the 4G63 will work. They are slightly wider and smaller in diameter, so the crank has to be machined. Before I stalled out on my 924 project, I bought a set of rods and had my crank machined. It all seems to fit together fine, but haven't gotten the motor together yet.
With the Mitsu rods, you get a 21mm(??) rod which has far more piston options than the 24mm(??) 924 rods.
Juho
PostPosted: Tue Mar 30, 2021 2:57 am    Post subject: Reply with quote
finding pistons for mitsu rods is harder
motormouth
PostPosted: Tue Mar 30, 2021 3:46 am    Post subject: Reply with quote
They’re 21mm. There were a lot of options I thought when I first started looking.
There’s a thread by ideola from a while ago on that topic.
anthonimartini
PostPosted: Tue Mar 30, 2021 3:41 pm    Post subject: Reply with quote
sooooo i found this....
https://www.aliexpress.com/item/32782381728.html
they list they exact dimension we need for either a stock piston or a vw flattop.
im gonna order and see what happens. i recently ordered a brand new head for a japanese import toyota van i have from a similar alibaba seller and the part arrived within 2 weeks. ali is legit.
current:
83 944
87 924S
Page 2 of 4
