1980 924 2.0 n/a hydraulic clutch upgrade
mistert1996
PostPosted: Mon Feb 22, 2021 7:58 am    Post subject: 1980 924 2.0 n/a hydraulic clutch upgrade Reply with quote
so im after some information if anyone has done it before and how?
prity much im putting a diffrent engine in and need a hydraulic clutch.
as far as i can see the firewall is slightly diffrent to the 944 with a stock hydraulic clutch so i dont know if i can just make one fit?
PostPosted: Mon Feb 22, 2021 6:17 pm    Post subject: Reply with quote
Firewall is identical.
Even the indents where you need to drill the holes are there.
The firewall is pretty weak in that area though, so you may want to look into bracing it or reinforcing it somehow.
I didnt when i converted my NA to turbo hydraulic clutch and the firewall was flexible, affecting the pedal feel...and eventually cracking. I then had to reinforce the whole area.
PostPosted: Mon Feb 22, 2021 11:10 pm    Post subject: Reply with quote
Look up only944.com, you'll see what a firewall brace would look like.
Mike
PostPosted: Tue Feb 23, 2021 12:22 am    Post subject: Reply with quote
Turbo pedal assembly might be different...check PET
PostPosted: Tue Feb 23, 2021 12:36 am    Post subject: Reply with quote
It is, you need the complete 944/931 clutch pedal assy as well as the master/slave cyl....also you need the 931 bellhousing and probably the clutch as well.
944 pedal shape is also different from the 931.
Good luck.
mistert1996
PostPosted: Tue Feb 23, 2021 7:00 am    Post subject: Reply with quote
do you have any pic of yours as my firewall looks different from what ive seen
i would put a pic of mine but i dont now how
edit i should have said it is rhd
PostPosted: Tue Feb 23, 2021 3:35 pm    Post subject: Reply with quote
Ah, haha well then you need more stuff.
The master cyl is located on the LHD side like on the LHD cars, you just get a long connecting rod that is linking the rhd pedal assy with the lhd master cyl.
Its how the factory did it. Have a loot in PET.
I’ll try to find some pictures later but open the porsche parts catalogue and you’ll see there exactly what parts you need.
peterld
PostPosted: Tue Feb 23, 2021 11:26 pm    Post subject: Reply with quote
Morghen....that's for the brakes.
Clutch master on RHD cars is on the RHS. Pedal acts on master cylinder through the firewall, with the fluid reservoir sitting higher attached via a flexi hose to the master cyl. Fluid from the master travels via a hard line to the slave cylinder mounted high up on the left side of the bellhousing above the starter motor.
80/81 932/8 ROW
PostPosted: Wed Feb 24, 2021 12:26 am    Post subject: Reply with quote
Ah crap, it was too early for me in the morning, sorry.
peterld
PostPosted: Wed Feb 24, 2021 1:23 am    Post subject: Reply with quote
And it's way too late for me at night!
80/81 932/8 ROW
mistert1996
PostPosted: Sun Feb 28, 2021 9:42 pm    Post subject: Reply with quote
so this should be some links so you can see what i am working with
[img]https://lh3.googleusercontent.com/RgYfeNAxLJi4PvM384SjFbni9j08Kd0kz-qW5XAspgzL5_iKzVnd6PDvoqYqr_Zmctjg3JDF3SsvFaodEThRuUjNpP1qBgvA3XpZn6yFfptzEz3ZS0KgK9a8-P0zEfY3qrekZkwUOgS3SuXndx0qa2mW5cimU6B2pjE9hklikB8MSh9mNWtxXrej_eowREC9HdpXF-566nZQ9_oD0rTyqDCd_fkvT9Fvg5DyYxtTUuFYEfQHvSSB9xZOD69m4DXuvN02Vh73YZCait2AB_byokibl7b9--8jyfv3YIw4jrq2pbPVOSQ-XjPewnsEx9b3QbmAjYyL3zEd5X_99nwFBhQkaQ0kUWEA-T6jA9EemAzETRLUFXbh6Fyjz_ixIXDtu1DIdm6mxSAZ3zPVPX_kpKPzc5O3USWpafnXanZ4nph5LlM2DAFm_Nn480WuMMDOLgeYvsVbVkcFKogy8l3i2k7nt7Ckwob4Omk_mg8HsetzsRo2MX9BIC-RKsk4EWCGOnVfZ8coEH8KFpNf5Uv9Aa4IdXbBJwOOE-3S5YJ8oXfqktRmUyUTHaQDfnfuFIOxCjt-Xz4_IhphnyiXCo1zd2-mkH1AV26HLrqmAzQDUp1dfk-dAK3SGje26n4GsRtFEwAfO9PT3BznVB7XjF0mD9WLOnBfkz-PwdW1GdSa-bUaoU4hr0vPRqj7r7XzLg=w640-h480-no?authuser=0
[/img]https://lh3.googleusercontent.com/O3ZrOQBmaHtxUVAt-b1WRj47S0_NpsKr6C1bwxkKmrxOwALz2mOC8Q4Nw2120UC2Bqsai6PFbQ_0uPjFr4V4MeHnbe5su3ccA_oV9cP2rQxJ13QwTrfzP4SHIdIHNFFmj3qyYU-r3dllUNEkTXLqDAE-mZDj9bJx1mtgCR0DNThlyUsXfzN1_nGwD9GFBiHSsvgcWhLqSsh7-dyi2Qx34zHOWPEToyRiyHTveVWUeZQxAQ_IWX_NAxB6TqRp7fAUar1g4KAixnX1i5ljYtXpLx3w3bHH71gsIjPClnuvVCilaltAd1DPiZOBnDoup8BV-fQRwtftD5YmsnT7pmJSkE-O1rHlCQnQ40BggWfQ2GUwAKFfJaQyS5XOguz1X-9AK6zJ_0g0hZn4stZySM7KtNXymUfhC3iFZEBZ-eM_Y8oxXeGGzpdIq4ZhjHfzYnCU2MYHCb8NEiUwnj4Y4VhjzPtDi9fxSk1FdBdFRgpC8y25hiNKY11i2ZCtBmz1MA-9bubJvcl45NTgl6k3Q3C5spTdbsbPsCKZ_aeGbbnMLEEV530qQFvLicboIffmIaV3z4aGAwjtyHPUWTd2tuAW1GsKcYdY3U0kkT62e0neEcI_ngUOcErGR7LEHGiakJeBtpt1qR_A1mlZ0-UwKIb1ue9xzc4TNUl_CtB6jH4d307l6lk-mc2i-AQtWcfkXg=w640-h480-no?authuser=0
PostPosted: Mon Mar 01, 2021 1:12 am    Post subject: Reply with quote
Raceboy
PostPosted: Mon Mar 15, 2021 12:40 am    Post subject: Reply with quote
Doing the conversion on early (76-79) is different than later where firewalls are identical. I just did the conversion on my '78 CGT project and it required much more work compared to my '83 that I did like 10 years ago.
You only need clutch pedal not the entire assembly since with early car you will not be able to retrofit servo system anyway. On later 924's you can.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
