1.8 turbo swap into tube chassis 924 gtr
Goto page Previous  1, 2, 3  Next
PostPosted: Thu Feb 18, 2021 1:05 am    Post subject: Reply with quote
If he's going to use a 944 style aluminium torque, perhaps since he's going to use a VW 1.8t..a VW gearbox would also be an interesting option if those gearboxes hold and offer the ratios he needs/wants.
Cheeky me pushing for that coupler i designed to be used
PostPosted: Thu Feb 18, 2021 1:17 am    Post subject: Reply with quote
Ok, I'll change my tune. If space and finances not an issue save all the original pieces so that the next owner can spend $150K turning it into a museum piece. Find a donor 931 and rebuild everything. There are several tranny specialists who post on Pelican Parts Board, Rebuilding torque tubes appear to be more a pain to do than difficult and drop in either a 1.8t or build a modern 931 motor using US head components and ACM followers, rods, pistons along with modern ignition controls(Mittlemotor?) and fuel injection and the duplex cooling system that GTR's used tuned to a reliable HP and have a great time. That leaves a good base for a future restoration and provides a great ride. Yes, I left out a lot of details like turbo, clutch, etc.
Like I said before, trying to change the transmission just opens up another big bag of worms.
Mike
PostPosted: Thu Feb 18, 2021 2:37 am    Post subject: Reply with quote
Well, I only advocated selling the GTR box because Scott does not want to hurt or repair it. Therefore, it isn't useful.
The g31 boxes are plenty strong for this application. The original engine is already gone, so if the car is only for enjoyment, seemed like a practical solution to me.
Scott Sanda
PostPosted: Fri Feb 19, 2021 1:50 am    Post subject: Reply with quote
Love all the discussion!
I have enough 924 motor parts to build up at least 2 complete engines. What i don't have is any of the original turbo bits and pieces, etc.
So the idea of building a "modern" Audi 100 truck based turbo motor is intriguing and possible, but even with new tech applied, the cars had a lot of issues.
head lifting being one of them. Peter Dawe told me they used to actually machine the heads and use an extended sleeve that went into the head with a O ring seal.
He also told me they ended up actually sealing the water passages between the head and the block and running totally separate cooling lines for each.
And they still blew up. So my guess is everyone who has one in original form and runs it has it way detuned, which is fine, and certainly fun.
Remember they were pushing 500+ HP out of these. Fastest things on the track until they popped.
Even a mild build on original equipment, say 300HP would be a hoot in vintage terms.
I'm stupid. I want to go faster. So replacing the 3L Na with a modern turbo capable of easily sustaining 250 HP/L fits what i want to do.
But I'm never going to make so many changes that it cannot be put back into "normal" form at some point. Probably right before I die, so my kids have some inheritance, since I plan on spending any available money
PostPosted: Fri Feb 19, 2021 2:08 am    Post subject: Reply with quote
Engine option.......proven in historic racing to deliver 395bhp, which is plenty enough for a lightweight 924 tubular chassis https://www.mittelmotor.de/racing/de/webshop/69044/6549/924-944/4-10-rennsport/4-01/2-4-01057-neu-detail Not cheap, but everything you need in a bolt in package.
PostPosted: Fri Feb 19, 2021 2:11 am    Post subject: Reply with quote
Carrera RSR wrote:
Engine option.......proven in historic racing to deliver 395bhp on cool days
ftfy
PostPosted: Fri Feb 19, 2021 3:39 am    Post subject: Reply with quote
I think you can expect good reliability with a 931 engine at the 400hp mark, as Joakim has proven over the years. The 1.8t would need a full bottom end build aswell, but have a better head as standard of course, but they need work to be reliable at high hp.
Do what you like best, any rolling car isbetter than a garaged one
PostPosted: Fri Feb 19, 2021 5:25 am    Post subject: Reply with quote
Rasta Monsta wrote:
ftfy
They will still run 375bhp at Nurburgring Classic for race durability. 395 is peak ability.
Mike9311
PostPosted: Fri Feb 19, 2021 5:32 am    Post subject: Reply with quote
Would be cool to scan the GTR trans....
My thoughts about some of the issues with the 2.0 are component weight and piston cooling. When I heard about how high these engines were/are revved, it blew my mind. Parts seem too heavy to handle those revs. I also have been dreaming of the best way to build piston oil squirters and hope to come up with this plan within the next month simply because I need them .
1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
1982 931 wana-be GTR race car
PostPosted: Sat Feb 20, 2021 3:59 am    Post subject: Reply with quote
Mittelmotor 924 GTS spec car at Nurburgring - https://youtu.be/3hIfyjbLApM
Customer car on the dyno - https://youtu.be/aCvEAD2Aoew
Scott Sanda
PostPosted: Sat Feb 20, 2021 7:15 am    Post subject: Reply with quote
https://youtu.be/kqwGx3ZDn-k Try this one for a fun dyno run.
PostPosted: Sat Feb 20, 2021 8:11 am    Post subject: Reply with quote
Awesome. Was that the 944 motor?
chuck21401
PostPosted: Sun Feb 21, 2021 3:06 am    Post subject: Reply with quote
I like it. That price though.
€ 42,500.01 All prices include 19% VAT.€ 6,785.72
1981 Porsche 931 w/S1 engine & euro g31 transaxle. Water-cooled intercooler
Scott Sanda
PostPosted: Sun Feb 21, 2021 3:50 am    Post subject: Reply with quote
technically a 968 motor. Finch cam profile, Mike mount built. KMR tuned.
PostPosted: Mon Feb 22, 2021 4:34 pm    Post subject: Reply with quote
What does it use for a turbo?
I can’t read...
80 Turbo - Slightly Modified
Page 2 of 3
