Substitute for This Coolant hose?
MikeDanger
PostPosted: Tue Feb 09, 2021 7:54 am    Post subject: Substitute for This Coolant hose? Reply with quote
the short 3" long hose that connects the WP to the Thermostat housing is weeping on my car.... can only find it as a Porsche OE part, $40!!!!! for a 3" long hose, COME ON!!
does anyone know the diameter? also BTW, how difficult is it to replace?
https://www.aasesales.com/products/noloc-b52-28i-116716
It was either this or a giant box of legos
BTRacing
PostPosted: Tue Feb 09, 2021 8:46 am    Post subject: Reply with quote
$40 is way cheaper then rebuilding overheated engine.
www.btrpalmbeach.com
2008 VW GOLF R32
1979 Glastron CVX 20
MikeDanger
PostPosted: Tue Feb 09, 2021 8:52 am    Post subject: Reply with quote
can I just sub with an off the shelf section of hose?
BTRacing
PostPosted: Tue Feb 09, 2021 8:56 am    Post subject: Reply with quote
Sure you can use generic one.
I would ask myself few questions.
How much cheaper is it going to be?
How much time are you going to waste making it fit ?
Is it going to fit as factory,molded one?
Are you sure that it is not going to leak?
All those questions for $40 ?
2008 VW GOLF R32
MikeDanger
PostPosted: Tue Feb 09, 2021 9:31 am    Post subject: Reply with quote
did you see the hose?
MikeDanger
PostPosted: Tue Feb 09, 2021 9:33 am    Post subject: Reply with quote
also, do I have to remove the Thermostat housing to replace the hose?
PostPosted: Tue Feb 09, 2021 5:52 pm    Post subject: Reply with quote
Yes 40 bucks for a hose is probably way more than its manufacturing price, but the hose is molded into a specific shape and it will guarantee another 40 years of driving without fear that it will burst.
Maybe a straight one could work(if made for the right temp and reinforced like the oem one) but the oem ones are bent to clear some stuff around there...so maybe a straight one will work for a while and then burst open due to something rubbing against it?
Like your Walmart carpet idea...its something new that may work for a short period of time...but not quite the right thing and in the end it adds to a botched up car that will feel and maybe even be unreliable and certainly not desirable in case of resale.
Then again..its 40 bucks man...you're driving a Porsche..still a hose but with a generic part replacement you're driving less of a Porsche...you're driving a low cost repaired thing that may or may not work as intended.
Then its the support the spare parts industry aspect...if we keep botching up our cars with random stuff and not buying original parts for them...we should not be surprised that many parts are not produced anymore.
Benino
PostPosted: Tue Feb 09, 2021 5:53 pm    Post subject: Reply with quote
The last time I replaced mine I did it without removing the thermostat housing. Sprayed he inside with armorall and slid it down onto the water pump and then back up onto the thermostat housing. I remember it being a bit of a struggle and the new hose was nice and playable. It would probably be more difficult with a piece of bulk hose.
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
PostPosted: Tue Feb 09, 2021 6:37 pm    Post subject: Reply with quote
Buy cheap.Buy twice. Fix it, don't bodge it!
PostPosted: Tue Feb 09, 2021 9:38 pm    Post subject: Reply with quote
I expect that a straight replacement will kink and not flow properly.
Raize
PostPosted: Tue Feb 09, 2021 10:57 pm    Post subject: Reply with quote
Maaaaaaaybe a 45 degree silicone hose? Ideally unreinforced for more flexibility.
PostPosted: Tue Feb 09, 2021 11:19 pm    Post subject: Reply with quote
A silicone straight, elbow and joiner will probably cost at least the $40 of the OEM rubber......having bought a lot of silicone for my build. I still kept the OEM bottom rubber hose. Plug and play!!
Raize
PostPosted: Tue Feb 09, 2021 11:36 pm    Post subject: Reply with quote
I was picturing one of these.
MikeDanger
PostPosted: Wed Feb 10, 2021 6:18 am    Post subject: Reply with quote
We'll see, anyone got Diameters?
Kenodog
PostPosted: Wed Feb 10, 2021 6:42 am    Post subject: Reply with quote
When I bought my dash and seat covers Werk924 had these I believe. Price was about 14 Euro....shipping might kill it though.
Wouldn't ever go cheap on stuff like this Mike, good straight heads are hard to come by. Ask me how I know...
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
