Timing question
rcarson25
PostPosted: Tue Dec 22, 2020 11:50 pm    Post subject: Timing question Reply with quote
I just did a timing belt and water pump on my newly acquired 1981 924 turbo. I have attempted to align the timing marks, but cannot seem to get the cam gear timing mark perfect. I have set #1 to TDC but the cam gear mark seems to be about 1/2 tooth off. Any suggestions or is this common. Thanks in advance.
PostPosted: Wed Dec 23, 2020 12:00 am    Post subject: Reply with quote
Probably due to head skimming. Better to be 1/2 tooth advanced than retarded. Only way to be cock on is a vernier pulley or thicker head gasket. Although the marks are a guide and not an absolute.
rcarson25
PostPosted: Wed Dec 23, 2020 12:38 am    Post subject: Reply with quote
Awesome, exactly what I wanted to hear advance is where I set it assuming that would be better as well.
PostPosted: Wed Dec 23, 2020 4:51 am    Post subject: Reply with quote
the crank pulley has a rotational tolerance, loosen the 6 bolts holding it and find its middle position, if you took it off and put it back in a hurry you may have not noticed that.
peterld
PostPosted: Wed Dec 23, 2020 10:39 pm    Post subject: Reply with quote
+1, plus the locating pin (Porsche calls it a tensioning sleeve) which locates the toothed belt pulley, can bend (particularly when using an impact tool to remove the bolt) throwing out the timing by several degrees.
Using proper engineering dowel pins (spring steel roll pins) is the answer.
80/81 932/8 ROW
