Golten951
Posted: Sat Jun 13, 2020 9:46 am Post subject: Time to work |
Hey all sorry for no new updates. With being DoD and having extreme travel restrictions have not been about to do anything since my 924 is outside or travel radius. How ever, I did get the time to head up with approval since my Son was born around Sacramento about 30 miles from my Dads. Come this monday/tuesday I will have some production updates!  |
Golten951
Posted: Wed Jun 17, 2020 3:34 pm Post subject: Calipers |
Worked on my Calipers today, Base coat color is down, next will be all new hardware, bleed ports, and turning the letters Silver.
Golten951
Posted: Thu Jul 02, 2020 12:15 pm Post subject: Caliper Progress |
Made some more progress on my calipers. First coat on Paint applied to the Letters and markings.
Golten951
Posted: Wed Jul 29, 2020 1:56 pm Post subject: Intake Manifold |
Did some work on my 4.2L intake. The lower air gate was jammed to the shut position which ends up breaking the Actuator arm. Next I will be sealing the intake back up and the wrapping it up for transport back up to my Dad's place where my 924 is
Here is a Picture of how the gates actuate.
Golten951
Posted: Thu Jul 30, 2020 1:36 pm Post subject: Headlights |
Gathered my parts for my Xenon conversion. Using the A8 headlight system and will adapt them into a set up 7" standard type round headlights. I will use the H7 based highbeams for a set of lights that will be in the bumper.
Golten951
Posted: Sat Sep 12, 2020 6:51 am Post subject: Update |
Come the end of this Month I will be able to work on my 4.2L swap a lot more. Since my 924 will be in my possession and not sitting at my Dads house. Very excited to get working on her again. ! I will up date when I start. Have a HUGE list to do lol.  |
Golten951
Posted: Sun Sep 27, 2020 11:56 am Post subject: Headers |
Worked on my Audi V8 headers for my 924 I still need two 3 to 2.5 reducers. they are just primed right now to keep some of the elements off the metal. They turned out pretty nice for mocking up on the car and then finishing off in my driveway. I used a header kit from Summit, then sliced the flanges off the stock A8 manifolds. They are not prefect. But will certainly do the job I need them to do.
Golten951
Posted: Tue Oct 13, 2020 6:06 am Post subject: Update |
I was able to do a little bit of work on my 924. I have the steering wheel and column set where I want. It will be electronically controlled for adjustment. Also gave my 924 a bit of a clean up after 5 years. Removed the 4 fog lights I had mounted to the bumper as well. going with a different idea for them. I will be Welding in brackets tomorrow to hard mount the steering column in place then I can work on the Brake and Clutch pedal.
Golten951
Golten951
Posted: Mon Nov 02, 2020 12:08 pm Post subject: Pictures |
Got some more good progress done on my swap.
Pedal box is all set up and welded.
Steering column is in and all welded.
Put the Instrument cluster in place just for fun to see how it looks.
Put the intake manifold in place and spaced up since I needed to flip is 180 degrees from the normal set up. I rotated the throttle body as well to clear the hood. I need to have a 10mm space made for the throttle body to intake. really happy with it all!
Golten951
Posted: Tue Nov 03, 2020 4:51 pm Post subject: Update |
More good progress today on my 924 Audi V8.
Finished getting my brake pedal box tacked in place. Need to make a lid for it next. Put the coolant reservoir in plan where I want to set it up.battery is going into the drivers side cubby hole.
Test fitted my A8 instrument cluster into the 924 dash. Fit great after I cut material away lol. Reason for using all the A8 stuff like whole steering column, steering wheel and cluster is I have to complete interior, exterior and engine harness from the A8 I got the engine from. Will make the wiring a lot smoother on install VS trying to match up all the 80s wiring to the newer 2000s wiring. A8 steering wheel will either be blank or might make my own special emblem for it.
Posted: Tue Nov 03, 2020 7:50 pm Post subject: |
cant wait to see videos of this thing driving  _________________ Supercharger and EFI kits
Golten951
Posted: Wed Nov 04, 2020 4:58 am Post subject: |
| morghen wrote: | cant wait to see videos of this thing driving  |
I am doing much as possible happy to have the car close to me now instead of 350+ miles away |
jazz guy
Posted: Wed Nov 04, 2020 8:53 am Post subject: |
That Audi engine looks good in there! Very ambitious project. Looking forward to more updates. _________________ '81/'81/'82 |
Golten951
Posted: Wed Nov 04, 2020 12:22 pm Post subject: |
| jazz guy wrote: | | That Audi engine looks good in there! Very ambitious project. Looking forward to more updates. |
Thank you much! The engine certainly matches the car. It is going to be heaps of fun. I will update as I go. |
