alternative brake master cylinder
MikeDanger
PostPosted: Sun Oct 18, 2020 10:50 am    Post subject: alternative brake master cylinder Reply with quote
My MC is leaking, and after a bit of research, I can't find an MC rebuild kit?
But I found this instead... first on a 911 forum, which lead to a VW forum...
the 80's audi 5000 uses a 23mm MC (and some reports of a version with a 25mm)
wonder if this option could work? (never mind the price, RockAuto has some for as low as $30, this listing just had the best pics)
https://www.ebay.com/itm/Genuine-Audi-ATE-Teves-Master-Cylinder-857611019-5000-Quattro/303033949917?fits=Model%3A5000%7CMake%3AAudi&epid=10028231217&hash=item468e3b1edd:g:~d0AAOSwvNVcQhMR
Might need some hose rearanging but if it bolts up to the Booster?
It was either this or a giant box of legos
MikeDanger
PostPosted: Tue Oct 27, 2020 3:47 pm    Post subject: Reply with quote
anyone?
PostPosted: Wed Oct 28, 2020 1:24 am    Post subject: Reply with quote
Any 944 master perhaps?
80 Turbo - Slightly Modified
Mike9311
PostPosted: Wed Oct 28, 2020 1:35 am    Post subject: Reply with quote
11-2742 is on the '82 931. Got it for $84 +ship
I searched around for PN's cross references all over eBay
1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
1982 931 wana-be GTR race car
MikeDanger
PostPosted: Wed Oct 28, 2020 6:32 pm    Post subject: Reply with quote
only thing I could find was $250!
MikeDanger
PostPosted: Wed Oct 28, 2020 6:33 pm    Post subject: Reply with quote
no they are stepped
Coco_Lev
PostPosted: Wed Oct 28, 2020 6:53 pm    Post subject: Reply with quote
you've the 23,81mm master cylinder?
Here is your kit https://www.rosepassion.com/en/92835591300-p23055-repair-kit-P23055
But first disassemble your MC before buying new parts. If the bore is worn, a new seal kit won't solve the problem.
PostPosted: Thu Oct 29, 2020 1:27 am    Post subject: Reply with quote
MikeDanger wrote:
no they are stepped
They only really have one pressure piston in them so their is no bias f/r for any 924/944 master.. Pressure/volume is equal..
The 2nd piston is just a floating piston to separate the 2 chambers, pressure is only applied by the main piston..
What IS stepped is the volume loss needed to operate in failsafe mode, where it splits the chambers so you still have 2 brakes if you loose pressure on the other pair.. It's the safety system in them that changes a little for different volume calipers they were intended to operate with..
The calipers on the 924 5 lug and early 944 are the same anyway, the only difference is X split vs F/R split..
MikeDanger
PostPosted: Sat Oct 31, 2020 2:32 pm    Post subject: Reply with quote
Fasteddie313 wrote:
MikeDanger wrote:
no they are stepped
Im not sure about that, searching for using 944MC on 924 says no.
PostPosted: Sat Oct 31, 2020 5:33 pm    Post subject: Reply with quote
If you switch to 944MC then you need to swap out all other braking components to 944 spec. Servo and more importantly the line routing to front/rear from diagonal. Or just buy a new 931 MC. When I did mine a new MC was circa £100 and rebuild kit was circa £80. Why rebuild??
MikeDanger
PostPosted: Sat Oct 31, 2020 6:01 pm    Post subject: Reply with quote
the ones I have seen listed new are over $200!
PostPosted: Sun Nov 01, 2020 2:36 am    Post subject: Reply with quote
The picture is wrong, but I entered 81 931 and it shows a price of $94 with a lifetime guarantee.
https://shop.advanceautoparts.com/p/carquest-wearever-brake-master-cylinder-mca22977/10193320-P?searchTerm=brake%20master%20cylinder
