924 Turbo no midrange power
Pittspirate
PostPosted: Thu Sep 17, 2020 1:01 pm    Post subject: 924 Turbo no midrange power Reply with quote
Long time 924 owner. I’ve had my 79 over 30 years.
My son recently acquired an 81 turbo. It was a bit of a project, but it’s on the road now.
Main problem is that it bogs under hard acceleration. As soon as the turbo spools up, the car dies, let off, it’s fine. Under modest acceleration, half throttle, it’s okay, but as turbo kicks in around around 3000, it dies.
Main pump pressure is ~80psi at regulator. Control pressure is same after warm up at idle. Suspecting WUR, any comments as to whether I’m on the right track? Anything more likely to be the culprit.
If, for some reason, the frequency valve wasn’t operating, would these be the symptoms? F/V bench tests okay. Micro switches on throttle body okay.
Open to any suggestions
Thanks
gerben1986
PostPosted: Thu Sep 17, 2020 7:53 pm    Post subject: Reply with quote
Fuelfilter blocked as soon as it tries to get more fuel?
911SC - 1980
chuck21401
PostPosted: Thu Sep 17, 2020 9:55 pm    Post subject: Reply with quote
If you don’t have one already, suggest connecting boost gauge, at least temporarily to see what kind of boost you have when it cuts out. Have you tried grounding the overboost switch? That cuts the fuel when there is too much boost.
Run some searches in this forum...could be any number of things.
1981 Porsche 931 w/S1 engine & euro g31 transaxle. Water-cooled intercooler
Pittspirate
PostPosted: Fri Sep 18, 2020 12:18 am    Post subject: Reply with quote
Drove with pressure gauge on, under load and when bogging, pressure remained constant, so I don’t think it’s a clogged filter.
Waste gate disassembled, inspected, re-assembled, tested okay
Have by-passed overboost switch, no difference
I haven’t found a definitive answer to what the warm control system pressure should be on this car. Right now, when it’s warm. Control system pressure when warm is equal to main system pressure. It doesn’t change under load.
Although I understand K-Jetronic, The lambda system is new to me. Should the control system pressure drop as frequency valve begins to cycle? As I said if WUR numbers are normal, I think I need to look at emission.
Agreed, a boost gauge is a good idea, but engine bogs as soon as I hear the turbo spolling up.
I think I read about a dwell meter on the frequency valve. Would anyone concur that this is the next logical step?
Thanks
jazz guy
PostPosted: Fri Sep 18, 2020 1:22 am    Post subject: Reply with quote
Boost leak? The o-ring seals on both ends of the charge pipe are known failure points. When I've run into this, the car will idle but immediately bogs as boost comes on. Though when it happened, I'm not sure mine ran well enough to drive. Limp home maybe.
'81/'81/'82
Mike9311
PostPosted: Fri Sep 18, 2020 2:55 am    Post subject: Reply with quote
I second jazzguy
Look to see if the upper o-ring to the throttle body is sticking out at all. If you don't have the spacer between pipe and throttle body which a lot of 81-82's don't, it could be popping out under boost but sealing enough to seem fine
Happened to me too at one point
1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
1982 931 wana-be GTR race car
PostPosted: Fri Sep 18, 2020 4:08 am    Post subject: Reply with quote
Mike9311 wrote:
I second jazzguy
I don't buy the black spacer/finisher ring allows the inner O ring to pop out on boost. I have run over 1 bar without that black ring. But for sure the o rings need to be checked to make sure no boost is leaking out.
Mike9311
PostPosted: Fri Sep 18, 2020 4:38 am    Post subject: Reply with quote
It happened
Middle of the night after wrenching I drove it down the street. Boosted it a bit and the car started running super crappy then died. Wouldn't hold an idle after that and I proceeded to kill the battery trying to get it restarted
Could not see the issue there and ended up pushing it back with one other person roughly a quarter mile. Initially to get under a street light but in the end all the way back.
O-ring was popped and I wouldn't have believed it myself without witnessing personally so I get the pessimism
Edit: ohh... no ring in my case. Its why I Print them now. It wasn't the whole o-ring either. Just a little section of it popping out
1980 931 since 1989
Pittspirate
PostPosted: Fri Sep 18, 2020 5:37 am    Post subject: Reply with quote
O Ring ‘looks’ okay, but I understand how this could be the problem. A boost gauge would tell the tale as previously mentioned, thanks
Again, any comments as to WUR pressures, possibly checking frequency valve dwell would also be appreciated.
Simple things first!
PostPosted: Fri Sep 18, 2020 6:49 am    Post subject: Reply with quote
The three pronged test plug coming out of the firewall to the outside side of the brake booster.. The black wire.. Is the test port to read the frequency valve duty cycle.. Easily read with a dwell meter..
The duty cycle of the frequency valve should adjust to get the o2 sensor to read/cross stioch..
At idle, adjust the AFR screw to where the dwell meter reads at average 45%, but it will be crossing back and forth +- a few %..
Make sure to plug the AFR screw access hole while reading and for running as it itself is a vacuum leak..
Otherwise, your symptoms sound like a boost leak where the upper charge tube meets the throttle body, or where the lower charge tube meets the turbocharger, to me..
80 Turbo - Slightly Modified
bureau13
PostPosted: Fri Sep 18, 2020 2:30 pm    Post subject: Reply with quote
I highly recommend you get or make a smoke tester. I found a bunch of vacuum leaks during my recent "troubles." None of them were the actual problem, but that's another subject
You can buy very expensive professional smoke testers, or you can buy the cheap ones from eBay (that's what I did) or you can make them yourself for even less. Super valuable for this task.
1986.5 Silver 928S
2008 Volvo XC90 (Daily)
Past lives (I miss them all):
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen)
bureau13
PostPosted: Fri Sep 18, 2020 2:44 pm    Post subject: Reply with quote
Regarding the frequency valve, I'm no expert (AT ALL) but I had to do quite a bit of research into the lambda system while diagnosing what ended up being a bad coil (that's how much of an expert I am ) This site was invaluable:
https://jimsbasementworkshop.com/CIS/pages/descr_lambda.html
Yes, it's for a NA 911, so it doesn't show the big role the WUR plays in on-boost enrichment, but from what I gather, the lambda system works pretty much the same as for our cars.
In short, since you've confirmed that the frequency valve is doing something, I suspect it is NOT the source of your problem. I guess if you have a dwell meter it sounds like a pretty easy test. I don't have one so I only went as far as "is it buzzing when it should?"
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
PostPosted: Fri Sep 18, 2020 9:05 pm    Post subject: Reply with quote
Well, WUR sounds bad, common for those that've sat for a while. Control pressure shouldn't be the same as fuel delivery pressure. It varies with temp, but at 20C it should be between 2.4-2.8 bar = 35-41psi.
With the engine warmed, it should be 50-55psi, without boost. It should drop with boost to 2.7-3.1 bar/39-45psi.
So you probably need to have it cleaned/rebuilt. Along with fixing your boost issues.
Pittspirate
PostPosted: Sat Sep 19, 2020 9:02 am    Post subject: Reply with quote
Re-ran. WUR test. Operating pressure ~74, cold control pressure ~74.
Going to solve this first. Will keep you all posted
Thanks
