Preferred location for mounting underhood MBC
Goto page Previous  1, 2, 3  Next
chuck21401
PostPosted: Thu May 28, 2020 10:57 am    Post subject: Reply with quote
bureau13 wrote:
Chuck, you and I were following a very similar path, until you lucked into that Trust controller. You don't see those too often! Got to put that beast inside
The Trust controller looks pretty cool. I figured that it wouldn't be available for long. I might have to mount it like this:
PostPosted: Fri May 29, 2020 12:44 am    Post subject: Reply with quote
Since im an engineer i wanted to buy something that is acutally engineered and have a specification sheet So i bought a precision pneumatic 3 bar pressure regulator. It works flawless and gives rock solid boost. Didnt cost more than the blue blingy things. I have a small version aswell, but this looks cooler and more old school, so its the one I have in the car. At the moment its in the battery tray, but Im thinking about mounting it in the glovebox instead
One day i will swap out the knob to something similar to the old school ones being discussed here.
Riegler 3 bar high precision regulator
Mike9311
PostPosted: Fri May 29, 2020 1:36 am    Post subject: Reply with quote
Cedric, what is the thread size on your regulator?
1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
1982 931 wana-be GTR race car
PostPosted: Fri May 29, 2020 3:13 am    Post subject: Reply with quote
G1/2, so i had to search around a bit to find a reducer to a small vac line
Mike9311
PostPosted: Fri May 29, 2020 3:28 am    Post subject: Reply with quote
Sorry, not the for the fittings but for the knob?
Edit: and yes, G1/2 is huge. Over here in the US we get a lot of people trying to cross thread 1/8NPT into G1/4 (BSPP)
1980 931 since 1989
PostPosted: Fri May 29, 2020 4:06 am    Post subject: Reply with quote
Haha, I havent removed the knob yet, so i haven't actually assessed what i need to get a different knob on there
chuck21401
PostPosted: Sun May 31, 2020 2:05 am    Post subject: Reply with quote
By any chance do you have any pics of how you have that mounted and how you ran the lines?
PostPosted: Sun May 31, 2020 4:45 am    Post subject: Reply with quote
Haha, i won't show that mess its routed through a heat protective sleeve and then through the drain hole into the tray, and it's just sitting there, not fastened at all, since everything is temporary
PostPosted: Mon Jun 01, 2020 6:12 am    Post subject: Reply with quote
Need the same racey interior too
chuck21401
PostPosted: Tue Jun 02, 2020 12:21 am    Post subject: Reply with quote
The 924 GTR interior is less spartan
Wonder if they would take a trade in?
https://www.porschenorthhouston.com/used-Houston-1981-Porsche-924+Carrera+GTR-1+of+17-0WP0ZZZ932BS72010
chuck21401
PostPosted: Tue Jun 02, 2020 12:22 am    Post subject: Reply with quote
Trying to figure out if the boost controller would fit in there next to my battery. It would be tight.
Mike9311
PostPosted: Tue Jun 02, 2020 4:50 am    Post subject: Reply with quote
You know my memory is being tweaked... I seem to remember back in the 90's, somebody running a manual boost controller somewhere around the ignition coil. I wish I could remember if it was a single setup or aftermarket
1980 931 since 1989
PostPosted: Wed Jun 03, 2020 4:09 am    Post subject: Reply with quote
I was standing in front of that car 2yrs or so ago when it was in the Porsche Experience Centre UK prior to auction. Spent a good hour sucking it up. Would have spent longer if I didn't have to get on the test track that day. Shame we weren't allowed to sit in it or start it
poor-sche
PostPosted: Tue Jun 16, 2020 2:47 am    Post subject: Reply with quote
chuck21401 wrote:
This is my temporary set up and recognize that it isn't ideal.
It does take some fiddling to get the boost level right. I found that even a 1/4 turn can make a huge difference.
I've found that the boost level is mostly consistent...but after a long run the boost level creeps up. I'm wondering if it has to do with heat....and if that is the case...would need to find a cooler spot under hood.
I installed a turbonetics MBC over the weekend similarly to what you show in your picture but it doesn't seem to work. No matter the adjustment, 7 psi is the max boost I see on the in cabin gauge.
The strange thing is that previously it was set to 10 psi with a small spring loaded valve that worked fine. Since I couldn't get the turbonetics MBC to work, I reinstalled the previous setup, but now adjustments don't work on that one neither.
Any thoughts?
chuck21401
PostPosted: Tue Jun 16, 2020 3:17 am    Post subject: Reply with quote
Any thoughts?
If the WG is opening at 7psi that tells me that the line is not being restricted and that you don't have leaks in the control line...enough air is pushing the spring up to open the WG.
When I first connected the turbonetics MBC it didn't seem to work. I cranked it all the way UP (+) according to the +/- on the dial....and still had stock boost. It took me a while to figure out that turning the knob down actually increases the boost...turning it down restricts the flow. I turned the knob all the way down (-) and the boost went to the moon...I let off the gas as I saw the boost gauge heading to 12psi in a hurry. From there I was able to adjust it to 9/10psi. As I mentioned above...a 1/4 turn makes a big difference....so it might take several runs to dial it in.
Can you remove the MBC and test it to make sure that air is being restricted? If you turn it all the way down...no air should pass through it. Of course make sure the air is flowing the right direction. If you connect it backwards it might not work correctly.
That doesn't make sense. Not sure what is going on there.
Page 2 of 3
