poor-sche
Joined: 06 Jan 2017 Posts: 80 Location: Los Angeles, CA
Posted: Wed May 13, 2020 1:52 am Post subject: |
Yeah, it looked fine. Nothing was gummed up. I figured the problem/blockage might be in the screen, but I couldn't remove it. Still cant, i'm guessing its soldered in place cause I can't remove the pieces from around the edge of the hole. _________________ 1980 - 931 |
poor-sche
Posted: Thu May 14, 2020 1:04 pm Post subject: |
After finally getting the screens removed I cleaned it up in an ultrasonic cleaner.
CIS pressure (3rd) test results:
Ambient temp | 22C | 72F
System Pressure | 6.0 bar
Cold Pressure | 2.7 bar
Warm Pressure | 3.9 bar
Leak Test @ 10 min. | 2.0 bar
Leak Test @ 20 min. | 1.9
Better results but still a little off from optimal I suppose. _________________ 1980 - 931 |
