Joined: 29 Jul 2001 Posts: 9073 Location: Royal Oak, MI, USA
Posted: Wed Dec 11, 2019 1:12 am Post subject: I see why they call you Microsquirt... |
(riffing on the old joke)
Just noticed an enclosed, pre-built Microsquirt with 8' harness is all of $399USD on Amazon!
https://www.amazon.com/MegaSquirt-MicroSquirt-Engine-Management-Harness/dp/B081VVX2XB/ref=sr_1_1?keywords=Megasquirt&qid=1575989813&sr=8-1
Anyone know of any reason why this wouldn't work on a 931? Ready to get rid of my CIS and get reliable, get back to enjoying my car. Not a really extreme build; will be adding an IC as well, but seems like this would even be happier running just triggering the stock ignition unit, just eliminate the flaky stock crank position sensor and ignition controller... _________________ Vaughan Scott
kondzi
Posted: Wed Dec 11, 2019 3:47 am Post subject: |
I’ve built 3 cars using MS2. If I remember correctry Micro and MS1 could do either spark of EFI. Not both. But I might be wrong. _________________ ---
Konrad
'89 951 US
'88 Mustang 5.0 LX Convertible (factory specs)
'84 911 Carrera 3.2 RoW (factory specs)
'81 931 RoW (TBD)
'81 Ford Capri 2.8i (factory specs)
'79 Ford Capri 2.9 (heavily modded) |
Posted: Wed Dec 11, 2019 4:38 am Post subject: |
It should be possible to get that to work with some effort, a good deal for sure. Alot of stuff needs fixing to go full efi and spark, probably more than people first think.
I would really like to build a car with the speeduino system, a very clever open source system with a great community. Theres already one guy on this board that has started such a project. _________________ 1980 924 Turbo
kondzi
Posted: Wed Dec 11, 2019 5:14 am Post subject: |
I’ve switched completely to Ecumaster, no more new projects based on MS. They are present in the EU and US as well. My last project https://youtu.be/EC1cGT3wNy8
Killer price/performance for the ECU (I use EMU Classic). _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Posted: Wed Dec 11, 2019 5:39 am Post subject: |
I read somewhere Raceboy was offering a plug and play VEMS EFI set up for 931. No idea the price or if everything needed is in the box _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Wed Dec 11, 2019 7:51 am Post subject: |
I have a microsquirt on my 931, kinda..
The hard parts will be, crank pickup trigger wheel, fuel rail, and TPS.. I think..
I have a good TPS/big TB solution for S1 though and will tell you all about it if you want..
I'm pretty sure microsquirt will batch fire 2 banks of injectors and 2 banks of coils just fine to run the 931..
And it is a bit cheaper right from DIYAT
https://www.diyautotune.com/product/microsquirt-engine-management-system-w-8-39-wiring-harness/
But IDK about shipping..
Another big expense will be a wideband and a quality MAP sensor, but are easy to do. _________________ 80 Turbo - Slightly Modified |
Posted: Wed Dec 11, 2019 8:14 am Post subject: |
Thankfully, mine's an S2, easy peasy just swap out the TPS with a modern sensor. Actually have some Ford ones sitting on the shelf unused, might be good enough.
Already have the WBO2 installed and functional; fuel rail on the shelf, and hope to grab one of Dan's trigger wheels in the clearance section... maybe a bracket too, but that'll be easy to fab if needed anyway (compared to others). Then a good fresh MAP sensor etc... _________________ Vaughan Scott
Posted: Wed Dec 11, 2019 10:43 am Post subject: Re: I see why they call you Microsquirt... |
| 924RACR wrote: | | Ready to get rid of my CIS and get reliable |
Another thing I'd like to say is this probably isn't a quick scheme to make a reliable DD..
If you are going to take over your CIS and ignition at the same time, it's might be complicated just to get the thing to start for the first time.. Then you are talking about hours and hours of tuning and learning..
Do you or anyone near you have experience setting up and tuning standalone?
Ignition and fuel, and my map will be useless to you..
I can literally unplug my microsquirt and my car will still run and drive, so it's not like I've gone through all that completely.. _________________ 80 Turbo - Slightly Modified |
KDJones2000
Posted: Wed Dec 11, 2019 3:28 pm Post subject: |
Some have tried MS on 951's and have blown their engines, at least from 5+ years ago. Something about losing crank position.
Just a cautionary tale... _________________ 1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S |
Posted: Wed Dec 11, 2019 11:28 pm Post subject: |
Yeah, I'm definitely not worried about our technical capabilities; my day job is SW development, calibration and testing in-vehicle for Bosch. Just not on the Powertrain side, and I have access to many who have powertrain calibration experience, OEM and aftermarket.
Gotta love the Motor City.
Though it could be a sticking point for others, your point is well-put... _________________ Vaughan Scott
